Question about Rio Audio Players & Recorders
2009 Kia Rio Sirius radio won't load Sirius. Stuck on SAT2
Just recently I went to load sirius and channel was on SAT2. Will not change to SAT3 or what I need SAT1
Posted by Tom Mohn on
5 Related Answers
Al42
Al Klein
  • 72 Answers
SOURCE: Sirius Radio Invalid Channel message
1) Do you have a Sirius account?
2) Have you called Sirius and given the serial number of that receiver?
Those are the first two things you have to do to get a Sirius receiver working. (The original owner could have changed his account to use his new receiver, if he has one.) Go to http://www.sirius.com/install - the "activate" part - for details.
Posted on Aug 20, 2008
marinos
Marinos
  • 114 Answers
SOURCE: Sirius Activations on VR 185 Jensen Radio
The user's manual containing the instructions can be downloaded here
http://www.asaelectronics.com/techpdf/VR185%20Owners%20Manual%2011-6-06.pdf
Thank you.
Posted on Aug 29, 2008
Anonymous
SOURCE: Clarion SIRIUS Radio Receiver - Not Receiving All Subscribed Channels
My DX445 does the same thing. Here's my method for fixing it, it should work for any similar Clarion receiver:
1. If possible, make sure the radio is turned off when disconnecting the battery. If the radio turns itself on when the vehicle is restarted (for example after jump starting or battery disconnect for a few seconds only), turn the radio off.
2. Disconnect the battery by removing the negative battery cable from the battery. Leave it disconnected.
NOTE: Car batteries can be dangerous things. If you're unsure how to do this safely, get an experiences mechanic to help you.
3. Reset the radio. On my radio this is done by removing the faceplated, and pressing a tiny button for 30 seconds. Your radio may be different.
4. After waiting at least 20 minutes, reconnect the battery.
5. My radio displayes 'System Check -- Press Power'. After pressing the power button, the display reverts to the clock.
6. Turn on the radio. It should work fine on the broadcast bands.
7. Select 'Sirius'. The radio should display 'Updating'. Don't touch anything until the radio finishes its update phase. When it's done, it should tune to Sirius channel 1 and play as normal.
8. This should restore normal tuning. reset your presets and preferences.
What seems to happen is that the radio gets stuck in a 'Category Select' condition, but not all the categories will load, and manual tuning will not allow, say, Radio Classics to play when the radio is stuck in Pop mode.
On occasion (maybe 1 time out of 10), the radio hangs while doing the 'updating' in Sirius mode. If this happens, just shut off the radio and start over. I've never had to do the brute force reset more than twice since I stumbled on this method.
Posted on Dec 09, 2008
Anonymous
  • 10 Answers
SOURCE: Do I need a Sirius radio antena for a MBB219
What you'll actually need in order to get Sirius is a satellite specific receiver (the JBL SIR 2.5 Satellite Receiver). That should come with the antenna you need.
Posted on Jun 04, 2009
Anonymous
SOURCE: Satellite radio (REF) not connecting with Sirius.
how do i use factory satalite antenna on a dodge ram 1500 2006 for after market radio
Posted on Feb 28, 2010
How do I reset a 2008 ford fusion stereo?
Hello Chad... As I'm not sure which SYNC Version you have, go here for info on "How To Perform A Master Reset"
https://owner.ford.com/how-tos/sync-technology/sync/settings/how-to-perform-a-master-reset.html
Jun 30, 2016 | Ford Cars & Trucks
How to see Sirius number on radio
Once you change the radio to Sirius, change the channel to channel 0 (zero). It should show the Radio ID on the screen.
Apr 25, 2014 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
What are SAT0 SAT1 SAT2 SAT3
Those are your hard drive connections. They start at 0 (that would be number 1) and so on making it 4 drives that you can install.
Some boards have many variations, including IDE (older hard connections), so make sure to do your homework by checking what type and versions it supports.
Try reposting with more details on your system, or you could just buy an external drive.
Feb 08, 2013 | HP Computers & Internet
I have a 625 dual tuner from Dish. When I do a check switch it shows that I have signals on both satellites on tuner 1 but tuner 2 has none. When I disconnect the cables from the receiver and reconnect...
Hi, Mary with Dish Network Customer Service, I will be happy to assist with this. This receiver needs to have a Separator (splitter) that has one coax cable coming from the Satellite into the single side and then two cables out, which connect to the receiver box. The Separator is marked with a SAT1 & SAT2. They will connect up to SAT1 & SAT2 on the receiver box itself. If you are using a different typr splitter, it is probably not rated for the splitting of the Satellite feed. I hope this helps you, if not feel free to contact me.
Jan 01, 2011 | DISH Network DVR-625 DTV Receiver /...
I have a Kenwood ddx6019 with XM satellite radio. recently, I entered a manual channel change and lost all reception. A banner reads LOADING LOADING across the bottom of the screen. Any ideas on how to...
I have a Kenwood ddx6019 with XM satellite radio and sirius. i want to know how do i turn on the xm so i can get live traffic update and my garmin gps unit and weather. and were to i find the mx radio id for xm. i found it for sirius
Nov 01, 2010 | Kenwood DDX-6019 Car DVD Player
Sirius S50 "No channels available"
I had the exact same problem happen to me yesterday with my S50. My guess is that the software got corrupted somehow. I fixed mine last night be reinstalling S50 software via USB cable to my PC. Note: You need My Sirius Studio application loaded on your PC. Be sure to press Exit button on My Sirius Software Ap after you reinstall S/W. Patiently wait for S50 to 100% complete before disconnecting. Then, manually turn on S50 (while holding in your hand); do NOT put in car/home dock yet. S50 will then update S/W. When this completes, now you can put in dock. I don't exactly recall, but I think the S50 indicated the dock was being updated, then it defaulted to channel 184 indicating to call Sirius to subscribe. Since I already have a subscription in place on my S50, I just pressed channel 2 (The Blend) from my remote, and then my S50 began updating all channels. Success! I'm so happy my S50 is now working again! Good luck to others experiencing same problem; hope this helps! I can only imagine the frustration trying to get help from Sirius folks for this type of problem...
Jun 24, 2010 | Sirius Satellite Radio S50-TK1 Satellite...
No signal problem on xm home satilite docking staion
You have probably lost a local repeater. Try moving it temporarily to a south-facing window. Here's another one to try: Put in dock and turn off with button on unit. wait 10 seconds, now press "2" "0" "7" "XM" buttons one at a time in that order ON THE FRONT of your SkyFi2 and the radio will go ON by itself! Now, press "Display" 4 times. You will see a screen that says "SAT1", "SAT2" and "TERR". You need a constant checkmark for DEMOD on at least one of the 3 boxes. Please tell me which ones are checkmarked and the average "BER%" number is. The lower the BER% number, the better. If BERis 100%, you are out of luck. Write back and let me know what you read. Press "Display" 5 more times to go back to regular screen. Thanks,
John
Aug 20, 2009 | Delphi SKYFi XM Radio Receiver
Aug 20, 2008 | Clarion (NAVSIR) SIRIUS Radio Receiver
Sirius Problem
The sirius unit does not have any channels in the unit.
You need to refresh the radio (XM allows you to do it online, I dont know about sirius) and leave it powered on for about an hour for it to update the channel list.
Mar 25, 2007 | Kenwood SIR-KEN1 SIRIUS Radio Receiver
118 people viewed this question
Top Rio Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
