Question about Windchaser Heating & Cooling
I need exhaust replacement parts for WindChaser model PACWAC Window and tubing conction
Posted by Cheryl Reagle on
Terry
  • Windchaser Master
  • 11,377 Answers
Http://dl.owneriq.net/2/2cc5235d-797f-4ccd-9b0d-315cac273ec5.pdf
Apparently manufacturer out of business:
http://www.fixya.com/support/t10242843-given_windchaser
Please verify the model number is correctly spelled:
PACWAC
Posted on Mar 10, 2018
Marvin
    Top Expert:
  • Windchaser Master
  • 85,239 Answers
Sorry we do not have parts here, nor do we have any locator service for parts for anything
Posted on Mar 09, 2018
5 Related Answers
Anonymous
  • 40 Answers
SOURCE: Parts
Google the model #. Then search for parts by proper names. You may even find an image of selected parts.
Posted on Jun 12, 2008
Anonymous
SOURCE: Windchaser PHS Patio Heater
try 1-800-405-2943 or 1-310-827-8615
www.windchaserproducts.com
Posted on Nov 06, 2008
Find all
Kimberly Opager
  • 36 Answers
SOURCE: replacement filters for the Windchaser 3 in 1
Here is the website for your manual. You can print it off. Page 8 says that the filters can be cleaned but that when they wear out you have to contact the company for replacement filters. The contact 800 number and address for Windchaser is on the last page of the manual.
http://www.windchaserproducts.com/manuals/WHRP_manual.htm
Posted on Jun 21, 2009
carl riggins
  • 70 Answers
SOURCE: I need an exhaust hose
You and get flex duct at lowes 6" 25' to a box that should work the same, In the heating cooling section.
Posted on Aug 28, 2010
claudeinmo
Claude Kayser
  • 9098 Answers
SOURCE: I need replacement parts for exhaust hose exhaust hose window slide bar connector a day adjustable let window bar slide. Does anybody know where to purchase these
TRY E-BAY USED CAR PARTS.
Posted on Jun 21, 2015
What causes the exhaust hose to get hot on a windchaser portable AC
make sure its not obstructed, then wrap it up with a towel or other insulative material. it heats up because the heat exhausts through that hose out the window.
Jun 28, 2014 | Windchaser PAC9 Air Conditioner
I have a unit with no exhauste hose conecter and no nozzel fitting covers or a window panel
Sadly this company seems to be out of business and parts unavailable. You can get vent hose at lowes. I attached the hose to a unit with a couple of small metal brackets, zip ties and vent tape. For the window part, I cut a piece of plywood, painted it white and cut a hole for the vent hose. Attached it with zip ties and silver vent tape.
May 24, 2012 | Windchaser PAC9 Air Conditioner
I have a PACRWC-HP. We only use it for short periods during Seattle summers. Now in it's third year, it does not evaporate the water filling the small overload every hour. Can it be fixed or should...
Jerry, Windchaser has been out of business for about 5 or 6 months. So, if it requires parts to fix the problem, it will difficult to find them. But, before you properly scrap the unit, check several of the things, that may be causing the problem.
1. The air intake filter may be dirty or clogged. Remove and clean thoroughly, if necessary.
2. The exhaust hose may be drooping from the unit to the window outlet. This allows condensation
to accumulate in the hose, rather than exhaust out the window.
3. Obstruction in exhaust hose will cause the same thing as in # 2. Remove the hose check & clear
any obstructions, as necessary.
I hope this has helped you troubleshoot, find and solve the problem. Thanks for choosing FixYa.
Aug 23, 2011 | Windchaser Portable Air Conditioner
A friend gave me it i know you have to catch water but does this need to be exausted and how and where
You will need the exhaust hose(s) & hose clamps and a window conversion kit for the hose(s). The unit has it's own water collection bucket, that will alert you when it's full and needs to be drained. It cannot have a continual drain as some water is required to keep the coils cool.
The biggest thing is where to get the parts? I say "biggest", as Windchaser is out of business. There phones have been disconnected and their website no longer exist. However, there is a company that may can help you, as some parts are interchangeable. Call Factory Appliance Parts .1-800-955-7075 and explain your circumstance and if there are interchangeable parts they are the folks to help you.
Good luck and thanks for choosing FixYa.
Aug 14, 2011 | Windchaser PACR10 Portable Air Conditioner
I need a connector for the exhaust port for the WINDCHASER PORTABLE AIR CONDITIONER PACR93S is there anything I can buy at the hardware stores that can replace those parts easily
I used a Plastic plumbing fitting, attached to the ac unit with a small metal braket. Sealed it wth thick foil tape. Sadly the company is out of business and the original flange connectors are unavailable.
Jul 19, 2011 | Windchaser PAC9 Air Conditioner
I need to get an exhaust kit and the adjustable part that goes in the window. Model PAC 9 Any idea where I can get this so that I can use my unit?
Sadly the company is out of business, so you will have to get a little creative like I did. I got what I needed at lowes, some flex duct, a pvc pipe fitting, small metal brackets, zip ties, thick foil tape, a piece of plywood for the window part, and some paint. Good luck.
Jul 12, 2011 | Windchaser PAC9 Air Conditioner
I need a adaptor that will allow me to vent my Windchaser Pac9 Model SA12059 through a window. Do you know where I can find one?
Sadly this company seems to be out of business, parts unavailable. You can get a little creative and make the pieces you need from off the shelf parts at lowes. I used a plastic pumbing fitting, some vent hose, two small metal brackets, zip ties, and thick foil tape to seal it.
Oct 11, 2010 | Windchaser PAC9 Air Conditioner
Aug 28, 2008 | Endless Summer 2009 Open Flame Patio...
Exhaust fan making loud noises
Still under warranty. put it back together and don't tell anyone you took it apart. Call the factory numbers and have them fix or replace it...let us know what happens..kraxytech
Sep 11, 2007 | Windchaser PACR10 Portable Air Conditioner
Heating & Cooling Logo
323 people viewed this question
Top Windchaser Heating & Cooling Experts
Marvin
Marvin
Dennis Boxerman
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
