SOURCE: My phone is sim lock on zte n160 model. How to unlock and to use?
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website Unlock-Zone.com which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
SOURCE: cd stuck in player
You'll have to unplug the unit and remove the cover to get it out. Be careful and good luck.
SOURCE: The key to my 05
Hi, the only part that dont have the circuit under neath is the part that has broken off the only chance you might have of finding somewhere to drill through is if you take the key apart and have a look on the inside and see if their is a small gap you can drill through.
if you just drill through without taking the case off you will never know whats under neath, now with the case off you may find a small part near the back of the key next to the part that broke off but it will only be a small area, so if you take the case off and drill a hole you will probably need one of those straps that go through a mobile phone, you know the string type that you feed through the hole on a mobile well you may be able to drill a small hole big enough to put this string through, but you wont be able to drill a hole big enough to put the metal ring through on its own.
if you can get the case off without damaging it then have a look at the back part near to the part that broke and you should find a small area to drill through, please dont drill anything without taking the key fab apart as you will drill through the circuit, its not worth guessing as damaging this could mean your car wont start.
failing that replacing the key is the only option
take the case off and have a look first just take your time and try not to break anything inside the key, if you have messed about fixing things before then you should be able to take the case off the key.
let me know if you need further assistance ok
SOURCE: how to get micro sim card stuck in motorola razr v without the sim card tray?
Exchange unit under manufacturers warranty.
While the Razr HD and Razr M use a micro-sim, the Razr V uses a normal sim(really a mini sim). The micro -sim is exactly half the size of the required sim and fits perfectly sideways into the slot. If you push it with another sim card you can make it click into and out of the mechanism. It will come back as far as the spring pushes it, but no further, and because it is only half the size, there is nothing to grip onto, and it is still under gentle pressure from the contacts. Removal of the the back cover and non-removable battery still does not allow access to the rear of the slot so the sim can be pushed out.
Ask Motorola for DOA warranty replacement and keep the faulty one as a 4" wifi tablet.
