1)Make sure the tower is powered on
2)Make sure the video cord from the tower to the monitor is fully connected on each end
3) Check for bent pins on either end of the cable
4)Replace the video cable with a new one.
5)Try another monitor if you have one just to verify you don't have a bad monitor
6) If none of the above works then the video display from your tower has stopped working. Either take it to a computer shop and have them repair it or purchase a video "graphics" card and install it into the computer. That should fix your problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
SOURCE: Monitor goes into sleep mode after a few seconds
Click on Programs --> Setting --> Control Panel
Choose the "Power Options"
in the "power schemes" Choose the Turnoff Montior, turnoff HDD, system standby
and system hibernate as "Never" in each combo box and clikc on apply.
repeat the above process for every power scheme options
Let me know if your problem is solved and rate me as FIXYA!
SOURCE: No DVi input, then computer goes to sleep
I have a new HP pavilion slimline with Vista......a 19 inch flatscreen monitor......I went nuts with it not connecting and saying no DVI input......
I tried something and so far it has worked 10 times in a row...
start out with puter and monitor off.......turn on monitor.......let it go to sleep....then turn on puter....
I have the puter that has the start button on top of it.....not too crazy about it.....
hope this works for you.........Judy in NY
SOURCE: Screen shows message "no input signal" and monitor goes to sleep.
monitor show "no input singnal" error masage when not gating any type of video singnal ,
so if u realy check your monitor wires for correctty plugged in .
then:-
Two possibilities:
either the video/mainboard of the monitor is defective; or
the video card/ CPU is the faulty.
A way to verify is to try the PC with another monitor or to try the monitor in another PC.
thanks
SOURCE: My Dell Optiplex 745 "No Boot Device Available"
No boot device means that the computer cannot find a drive that has a operating system files and therefore cannot boot up.
This usually means that the hard drive in the computer is faulty.
You need to get a new hard drive and install Windows on the hard drive, together with the drivers for the computer's installed devices and programs to get a working computer.
