Http://kitchen.manualsonline.com/manuals/mfg/jennair/m170.html
Toll free 800 number and email for support.
https://www.justanswer.com/appliance/6r6z4-dimensions-jenn-air-m170-built-in-microwave.html
Link above states:
What are the dimensions of the Jenn-Air M170 built-in Microwave...
What are the dimensions of the Jenn-Air M170 built-in Microwave Oven (built 1998) that I need to specify for a replacement unit? Externally, I see the frame measuring 26 3/4" W by 17" H, and the unit within the frame measuring 22" W by 13" H.
Share this conversation
Answered in 1 hour by:
6/5/2012
Appliance Technician: Ed Michaels
Ed Michaels :
Hi, your machine is long out of production and installation instructions usually come with the machine and are not published. you have a standard size 24" built in machine, and most 24" machines will fit the space. I would click on Jenn Air or call 1-800-JENN-AIR (536-6247) and ask for a replacement recommendation and a copy of old installation instructions for planning with designer or installer. They have access to records if anyone does and an interest in serving you. Alternatively, talk to another seller and discuss installation. they will also want to help. Let me know if I can help further.ed
SOURCE: Jenn-Air JMC7000 Microwave Stopped working
So it's dead? (No display, no inside lights, no beeps?)
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
SOURCE: Jenn Air JMC7000ADW
I would consider the
JMC9158BAW this is a 1.5 cubic ft, yours is 1.6, yours is about 24 inches and this one 24 inch, this model is a built in/countertop
the closet model you are going to find
Kitchenaid has the KBMS1454SSS 24inches comes with 27 and 30 inch trim kit
and KBMS1454S same specs just different model
SOURCE: Jenn-Air Microwave - no power
Had the same problem. Removed the unit (snapping off the upper and lower trim rings was a chore but they do snap off) and tested the power. Plug behind the unit was good. Pulled the cover and checked the thermal fuse with ohm meter. No good. Replaced fuse, microwave would run for a second, then light goes dim and it buzzes, then it blew the fuse. Per above suspected Capacitor. Changed that, and we are back up and running. Thanks!!
SOURCE: Jenn-Air JMC7000 Microwave stop working
I have the same unit and age the JMC7000 everything appeared normal on the display and countdown etc...But it would not heat,I trouble shooted the problem and discovered it was a faulty door switch I replaced it and it works like new again.I ordered the part from www.repairclinic.com it's an easy fix.and costs a few bucks...
SOURCE: HOW TO REPLACE BLOWN FUSE
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
