Cameras Logo
Question about Nikon Cameras
Cant get my new Nikon Coolpix b500 to go pass date and time on start up.
Posted by Timothy Jackson on
Steve Alexander
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • Nikon Expert
  • 165 Answers
All I can say is FIRST is to fully charge the battery. If they are not rechargeable put fresh ones in.
Posted on Jun 02, 2018
5 Related Answers
leecom72
Lee Hodgson
  • 4810 Answers
SOURCE: asks to reset date and time evertime I turn it on
Hi there.
Yes there is a soloution to your problem, there is an internal lithium battery insider the camera that keeps the time and date, its this battery that needs to be changed.
Good luck and thanks for using FixYa!!
Posted on May 12, 2009
Anonymous
  • 797 Answers
SOURCE: Camera resets DATE and Time to Jan 2002 when
Some of these cameras cannot save the date, and has no internal battery to save the data. The best solution I have use is to buy another battery with these kinds of cameras and always have one charging, or take two batteries when you take pictures.
These older point and shoot cameras are nice, and slower than the newer ones, but will not save the data unless you keep the main battery in it, or replace the one to be charged with another battery within a very short time.
Posted on Sep 27, 2009
Anonymous
SOURCE: my new nikon Coolpix s710 cannot hold in memory
according to Nikon the inside battery is finished and has to be changed because memory is not working. Bring in the camera for repair.
Posted on Jan 14, 2010
  • 102366 Answers
SOURCE: how to change the date and time in Nikon coolpix
From the Setup menu, select Date. Here you can set your home and travel destination time zones and set the clock.
Posted on Jun 03, 2010
Anonymous
  • 85 Answers
SOURCE: hi, I have an nikon
1. In Set Up you must select the language you want to use by highlighting it then PRESS OK. If you don't do this then the date/time will not set.
2. When asked to set date and time you must select YES and press OK.
3. After completing each step you must press OK.
4. In the final step you must choose your preferred day/month/year display and then press OK.
If you don't press the OK button at each step the date and time will not set.
Posted on Aug 17, 2011
Nikon B500 camera. I put a new memory card in my Nikon B500 and the camera says 'card not present'.
Is it this type of card?
The B500 is compatible with SDHC and SDXC cards. That means you can use cards from 4GB all the way to the largest cards currently available. (at that time 128GB)
And is it less than 128GB?
Your Nikon Coolpix B500 Digital Camera is compatible with 16GB, 32GB, 64GB and 128GB SD, SDHC and SDXC memory cards.
https://www.google.com/search?q=nikon+coolpix+b500+compatible+memory+card
How do you reset a Nikon Coolpix B500 to default settings?
Starts here
2:02
22 second suggested clip
Screen. If so what you're going to do is again just scroll. Down all the way to the bottom here andMore
How to Factory Reset Nikon Coolpix Camera - YouTube
YouTube · Tech Talk
About featured snippets
Feedback
People also ask
How do I reset my Nikon Coolpix to factory settings?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
How do I reset my Nikon Coolpix camera?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
How do I reset my Nikon Coolpix p500?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
How do I reset my Nikon D5000 to factory settings?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
Feedback Web results
Reset All - Nikon Coolpix B500 Reference Manual [Page 160]
https://www.manualslib.com > ... > Reference manual
Nikon Coolpix B500 Manual Online: location data, Reset All. Press The D Button M Z Menu Icon M Location Data M K Button Set Whether Or Not To Add Shooting ...
2answers
Just purchased NIKON COOLPIX B500. I put in brand new Sandisk SD memory card And as soon as I shut the battery case the monitor says “this card cannot be used!” What’s up with that?
At the Time the Camera was made , Nikon lists a number of compatible memory cards. Each year both cameras and cards can read and write data faster. Cheap cards today can be read much faster than written. If any camera can take many photos in a short time, a slow cad will not allow the camera to operate as intended.
2answers
Why won't my Nikon Coolpix b500 (red) turn on? When I just press the on button, it shows a green light also. What does this mean?
The best solution would probably be to check with your seller if it's still under warranty and let him solve the problem, but in case you want to be sure, go through the manual of your camera to see what the lights mean, if you don't have a manual you can find it here:
Nikon Coolpix B500 PDF manual download
How do i record video with nikon coolpix b 500
The best solution would probably be to go through the manual of your camera to see what all of the buttons do, because I have a feeling that you still didn't figure out the basics of your device :) If you don't have a manual you can find it here:
1helpful
Just got a coolpix s3000 and have got a red clock symbol om the main screen which i cant remove. please help
Maybe you didn't set the time and date?
Go into the Setup menu and adjust the time and date.
4helpful
2answers
My new nikon Coolpix s710 cannot hold in memory any of the date settings. Each time i switch it on i have to put the date in.
2helpful
Nikon coolpix 3700 did not take picture
Nikon has a new firmware to solve this, try change the firmware... the last firmware is the 1.2
Top Nikon Cameras Experts
Steve
David Shaub
Are you a Nikon Camera Expert? Answer questions, earn points and help others
