Question about GE Cooktops
How much is it 4 5pc GE Cooktop Burner set in Black and how can i order it Mod#JGP636
Posted by james90732 on
5 Related Answers
Anonymous
SOURCE: error code
Same thing happened to me. Reset your stove top by flipping your fuse off. The stove top will reset and the error code will go away.
Posted on Sep 06, 2008
Anonymous
SOURCE: Stained gas range burner grates
Hey y'all. I have the same lame GE profile gas cooktop with the gray grates and burner covers. I know this is the expensive way to go, but I use Easy-Off "self-cleaning oven" oven cleaning spray. For about $5, you get 3 cleanings. It is a pain to do, but I have better things to do than scrub these grates all the time. I don't know why, but the baked on crud just drives me crazy. I tried everything to clean them completely. I even tried to scrub the darn things with a kitchen pumice stone(sold at walmart)but it is impossible to get the curvy areas clean. Now the paint has started to wear off on the burner covers.
I do not use the oven cleaner on the cooktop itself. I use soft-scrub with baking soda, then cover the cooktop with a sheet of heavy duty aluminum foil and cut out holes for the burners. This keeps most of the spills contained, and helps with cleanup.
I visited to the GE parts web page, and they only sell gray grates and covers. I am going to buy black BBQ grill paint(spray can)from Home Depot and try it on the burner covers first. They are the least expensive to replace if it fails, and if it works, I will paint the grates with this high temperature paint. I will keep you posted on the results.
Regards,
Laura D.
Posted on Sep 29, 2009
Anonymous
  • 232 Answers
SOURCE: The igniter on the right front burner of my GE Gas Cooktop
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Posted on Oct 17, 2009
Testimonial: "Thank you so much I followed your instructions...I think the problem was in the knob as you said...Thanks again!1"
milten1
milten1
  • 1304 Answers
the very first thing i would do here is to check the ignitor itself
under the head cap you should see two screws, once those are out you will be able to lift the burner plate, lift the burner plate, you will see, or should see the ignitor, and the wire.
i check this for voltage by unplugging the ignitor and olding the wire close to a ground, the metal body is good. Turn on the ignitor, becareful it is live. yhou shgould see a spark comming from the wire
if not check to make sure that wire is in position and on the spark module
if you do see a spark this way, just order the replacement ignitor
and install it when it arrives
appliancepartspros.com
part number AP3191250
Dennis Koenig
  • 221 Answers
SOURCE: Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Posted on Jan 30, 2010
Igniter will not work on one burner only
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 13, 2011 | GE Profile JGP636 Gas Cooktop
How to replace a cooktop drip pan
It's really simple. Remove the burner grates, removed the old drip pans, then drop in the new drip pans. You can order a new drip pan from partselect.com if you don't have one yet. Let me know how this works out and if you need any further help.
Benjamin
Nov 04, 2010 | GE Profile JGP636 Gas Cooktop
GE Profile JGP636 gas cooktop
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Jul 01, 2010 | GE Profile JGP636 Gas Cooktop
Where can I get replacement burner caps in black? At what cost?
try applianceparts.com or google your cooktops model number for parts for it.
Jun 22, 2010 | GE Profile JGP636 Gas Cooktop
I have a GE Profile gas cooktop. The small black pads (feet) under the grates are deteriorating. Where may I purchase new pads?
Hello. Any store that carries the GE Profile appliances, like Home Depot, can order them for you. Regards, Joe
Dec 09, 2009 | GE Profile JGP636 Gas Cooktop
Also need black rubber feet for GE cooktop grill.
They are available at www.helpfulparts.com.
Referred to as GE Gas Range Cooktop Grate Foot Pad, $1.73 each
Jul 04, 2009 | GE Profile JGP636 Gas Cooktop
Electric Glass GE Profile Cooktop Burner popping
yes the knob is attached to a switch and the switch to the burner by way of wires..you can get into the cook top.but with your description of whats going on i would have the switch with me and then may only have too take apart once.there is a chance your burner is bad,but as you describe the way the switch is acting is seems pretty sure just the switch.you can order switch on line you need your model and ser#
Jan 30, 2009 | GE Profile JGP636 Gas Cooktop
Cooktops Logo
233 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
