SOURCE: roper washing machine roper rax7245kqo
more than likely something is jamming your pump now your coming up on the post with another user as having the same problem but its not the same kind of machine im getting ready to answer the first user who has a front loader and it may pop up to you so disregard that. Reply to this message and ill tell you how to check yours
SOURCE: Roper washing machine won't drain
you must have forgotton to connect one of the springs that balance the drum
does it spin? drain pump is directly mounted on motor, works in spin. may need new pump. Whirlpool standard pump.
SOURCE: roper top load washing machine
Thank you, AlmostBob.
That was the correct solution. For only $17, my washer works again!! To bad for Sears.
SOURCE: Roper Washing Machine Repair
I believe Roper washers are manufactured by Whirlpool. The following link should provide you with the necessary steps in removing the washer casing, so you can access the pump:
http://www.fixya.com/support/r397092-replacing_water_pump
If this information is not correct, or if you require additional assistance, please let me know. I hope this helps you.
