Hello, Isa -
I suggest you contact the John Lewis company directly and ask what the i60 error code means for your model of dishwasher.
This is the link to the Contact Us page for the John Lewis company:
https://www.johnlewis.com/customer-services/essential-information
Best wishes.
SOURCE: whirlpool dishwasher drainage problem..
This sounds like a bad timer. The timer is what tells the pump to drain at specified times. If it gets a bad contact, that timed cycle won't happen.
PS: Do you know for sure that the drain is occurring in mid-cycle? If not, you may just have an obstruction in the drain and/or anti-siphon valve (where the hose connects under the dishwasher.
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
SOURCE: my john lewis mini helicopter auto stability control not flying
I had a similar problem with mine, check if the central shaft on which the blades turn hasn't become lose and is no longer engaging the gears on the underside of the helicopter.
If the whole shaft can move up and down then this probably means it has come loose, you can solve this by squeezing the lower set of blades towards the bottom gear with your fingers. You should feel the bottom blades move slightly down, if you push them too far they will stick against the main body so you might need to pull them up slightly.
Testimonial: "thanks very much, you are absolutely right about the problem. i had difficulty moving the blades so put some clingfilm (!) in the gap on the shaft."
