Ovens Logo
Question about Frigidaire Ovens
Need a oven thermostat for a Frigidaire regs36bcl*
Posted by cole3415 on
1helpful
I have a Frigidaire Electrolux Model FEB30S5ABB. The oven will not heat up to the correct temperature and the bottom element is not turning on. We checked the element at it checks out ok. What could be...
Hello lizzyd62 - Sounds like the mechanical thermostat, oven sensor or EOC needs to be diagnosed for replacement. I would suggest contacting a professional to move forward accurately.
Where is thermostat located in Frigidaire wall oven?
Hello Brad,
The thermostat is a small diameter appx. 6 inch long round probe it looks like this
11_4_2011_12_23_15_pm.jpgTo test it for proper functionality ya need to use a multi meter capiable of reading ohms of resistiance...unplug the sensor from the wiring and place the meter leads onto the 2 wire ends of the sensor and at room temperature once the oven has been off check for between 1060-1100 ohms at the sensor if its good,if the ohms value is much higher or lower that 1060-1100 at room temp. the sensor is defective.
GENE
Older Frigidaire electyri-clean range Model REG 533 * HD
I wish I had a solution for you...unfortunately I don't. However, if you know anywhere I might find a thermostat knob for this model I would be eternally grateful. I've been searching for 2 years for my mother. It's the knob with 5 settings (off, bake, broil, time-bake and clean).
Frigidaire oven is slow to heat then exceeds set temp set
Normally you should have an appliance spare parts supplier in your area. They generally stock all range of spares for all appliances. You need to pull plug out of the wall and remove the panel covering the wiring to gain access to the oven thermostat. Look carefully on the body of the thermostat and record any numbers you see on a sticker that's present. Then remove knob off in front of thermostat and see if there is a nut attached to the centre which holds the thermostat in position or if there are 2 screws holding the thermostat in place. Use this information to order the thermostat also quoting the oven model number.
Frigidaire oven doesn't hold temperture that its set at!
Hi, normally the thermostat thats blown/faulty. Will need a new one. Best of luck
Frigidaire oven is too hot by 50 deg.
Yes, I would say that the main oven thermostat is faulty and in need of replacing.
If you are in u/k then try the followinw.
www.espares.co.uk.
Hope this helps.
Plz leave feedback.
Thanks.
Dec 10, 2008 • Ovens
Frigidaire oven overheating
I would say that the oven thermostat is malfunctioning, and you will probably need a new one fitting.
Make sure the sensor inside the oven has not become detached, as this will make a differance.
Plz leave feedback.
Ta.
Oven
there is a thermostat adjustment screw which you can adjust to get preheated properly
Top Frigidaire Ovens Experts
Marvin
Marvin
David Shaub
nu267
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
