Question about Speed Washing Machines
When machine begins spin cycle,a whirring sound is generated,becoming worse as speed increases.i suspect the agitator is slipping
Posted by Peter Orangio on
  • vince Mar 06, 2018
    Peter could we get a model # tis a Speed Queen?
5 Related Answers
Anonymous
  • 126 Answers
SOURCE: Kenmore top loader washer noisey agitator
it sounds like the gear dogs in the agitator. pop he top of agitator and check. its a easy repair.
Posted on Jan 12, 2008
Mark Egan
  • 1214 Answers
SOURCE: GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Posted on Jan 26, 2009
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Posted on Jan 28, 2009
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Series 70 kenmore washer ,spin cycle not working
If the washer will fill and drain, but won't agitate or spin, you, indeed, may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupling can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria. Let me know if you have any questions. I hope you find this information helpful. NOTE: There are other problems that can cause the washer symptoms as you describe, but the motor coupling is the least expensive and easiest solution to try first. If the motor coupling is still intact, please let me know.
Posted on May 27, 2009
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: loud banging noise during washing cycle. Sounds
Grab the agitator at the base and attempt to rotate it clockwise and counter clock wise. It should remain firmly in place. If there is movement the agitator spline is worn.
This is your Agitator:
http://www.repairclinic.com/Appliance-Parts?s=t-WBSR3140DW-%3d%3dc201
It does not come with the fabric dispenser. It has to be ordered seperately. You should be able to transfer you old one to the new one if you do have to replace the agitator.
Besides the agitator the drive bell can also be the source of the noise. It is located under the agitator.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-WBSR3140DW-%3d%3dc239i1195917&PartID=1195917
This part is the most likely cause of the noise.
Thanks for using FixYa.
Kelly
Posted on Mar 07, 2010
Sent question,was asked Mod #... problem is washer ,when Speeding up for speed dry,makes whirring noise,gets louder as spin increases. I suspect agitator...is that reasonable?
I'd suggest two possibilities, both bearings.
As the mod suggests, the drive-motor bearings might have failed, but IME the brushes usually fail before the bearings.
I'd suggest that the main tub bearings are the most likely problem.
I'm not experienced with this model so I can't help with specifics.
The bearings are usually really cheap, but it can vary from really easy to simply-not-worth-the-trouble, to actually change-out the bearings, depending on the model.
If it's not worth it to change them, you can carry on using the machine until it fails, because you can't make it any worse. Make sure you stop using it once you get any signs of water leaks, because you don't want a room full of dirty water, do you.?
Mar 07, 2018 | Speed Washing Machines
Loud constant noise (metal on metal clicking / whirring / grinding) during spin cycle
renault laguna 2006 diesel. unlock code for radio... modell renrdw100-10 .
n874 security...
pls..
thanks
Nov 22, 2013 | Whirlpool Washing Machines
Our whirlpool top loading washer starts making a high pitched whirring noise in the beginning of the first spin cycle. Once it gets going full speed the noise stops. What could be?
If you can hear the motor humming during the spin cycle, it could signal a defective motor drive. It's possible for the motor to fail in just one direction, which may be why you only hear it some times.
This kind of issue often requires the help of a professional. To learn more about this issue, read Washing machine will not spin but will pump and agitate. I hope this helps.
Sep 12, 2012 | Whirlpool Washing Machines
Washer agitates off balance and makes a loud banging sound until movement stops at the beginning of rinse cycle, advice?
If it makes this noise in the agitate mode and not during the spin cycle, I would suspect that the transmission is going.
Jan 03, 2010 | Whirlpool Ultimate Care II GSW9650LW Top...
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool stylemaster 4217141 REV A Agitator/spin cycle broken
I have exactly the same problem as Jonthan, what's the solution?
Dec 24, 2008 | Washing Machines
Kenmore washer 24622300. clothes are very wet after spin cycle
washer may not be spining at all start in rinse cycle allow washer to wash and advance through cycle on it's own do not advance manually..after agitation listen for short pause after pause pump out should begin after pump out should be another short pause then spin should start..if spin does not start after 2nd pause suspect transmission if lid is raised spin may start but if it doesn't start during normal operation bad gearcase one other ck possible look underneath for oil it may be getting on clutch causing clutch to slip and not allow to spin full speed
Nov 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirring noise in spin cycle, 7 year old machine
Checking the pump woulb be the first step. The pump bearing get worn and begin to sqeal. If the pump is alright then the problem could be the spin bearing.
Oct 19, 2007 | Maytag Performa PAV2200
Aug 28, 2006 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Top Speed Washing Machines Experts
Marvin
Marvin
Vernon Taylor
Are you a Speed Washing Machine Expert? Answer questions, earn points and help others
