SOURCE: Need to put PowerShot Model 5700M together.
Lovenheim posted this diagram on http://www.maybenow.com/ and maybe it'll help you...
SOURCE: where can i find a firing pin assembly for a hilti
you can either call them direct at 1-800-879-8000 or try Hilti.com for the breakdown, I would try the phone call first. Let me know if you still have a problem.
SOURCE: how do you load the stapler, powershot 5700m
Here are the scanned images from the Black & Decker 5700 Powershot Instruction Manual. These are just the instructions and corresponding illustrations for how to load the stapler, but the full instruction manual is available here:
http://servicenet.blackanddecker.com/Products/Detail/5700#
SOURCE: I just bought a powershot
Hello, W/D here.
I'm not exactly familiar with your model, but have several others, and they resemble yours, so please take these directions as "generic".
Open the fill slide as if putting staples in the machine, making sure that all of the staples have been removed. Insert instead the brads down one staple channel. On my stapler/nailers it is the left channel, facing the gun from the rear. Look carefully on the sides of the gun and the ends as , usually, there is some indication of which channel to use, and you rs may well be the other side. Load and test the gun on some scrap wood. If necessary, change channels and try the other side.
Best regards, -- W/D--
here is the link to manual:
good luck
Thanks
