Question about Vehicle Parts & Accessories
We have fault F06 on battery charger CMP2100 Please advise
Posted by salah elsergany on
Sam Preve
  • 3 Answers
See below for specific description; but, I would guess your battery has a short. Maybe, your alternator/charging system is overcharging and is essentially boiling the battery internals. F06 The charger detected that the battery may be getting too hot (thermal runaway). The charger automatically shuts the current off if it detects the battery may be getting too hot or the battery may have a shorted cell. Have the battery checked or replaced.
Posted on Feb 26, 2019
2 Related Answers
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: whirlpool awo3561 fault showing as f06? what does
"F06" is a Motor Speed error code. It means the motor is not spinning, or you have a loss of commuincations between the Motor Control Unit (MCU), Central Control Unit (CCU) or Drive Motor. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
The easiest place to start would be to verify all your connections between the Drive Motor and MCU are intact and not corroded. Then, perform resistance checks on the Drive Motor windings.
For ease of troubleshooting, UNPLUG the washer and remove the top panel by removing the three screws that hold it in place in the rear of the washer. With the screws removed, the panel will slide back, then off. Position the washer where you have full access to the rear. Remove the back panel of washer. With the top and back removed you will have full access to the CCU, MCU and Drive Motor.
If you have questions along the way, or if you require addtional assistance, please let me know. I hope you find this information helpful.
Posted on Mar 05, 2009
auro48
auro48
SOURCE: indesit 123 FAULT F06
I had this error and engineer said the meaning of the codes on the web are wrong as they don't like to disclose their real code meanings for pure protectionism reasons. F06 on IWD7145 is a burnt out door interlock IDC error. He replaced the part number C00085194 (replacement door interlock) and microritardator part number 085194 and it works ok now.
Posted on Sep 26, 2012
Error Code 01 F06
Your fault is mentioned here.
An F06 fault code in a Whirlpool Duet washer (the Kenmore HE3/4t's are also made by Whirlpool) usually means a motor-related problem. It usually pops up when the drum won't rotate at all or only very sluggishly. Here's the excerpt from the Whirlpool Duet Service Manual on this:
http://fixitnow.com/wp/2008/10/28/whirlpool-duet-washer-with-an-f06-fault-code/
May 10, 2015 | Maytag Dryers
Freerider mobility scooter
hi, okay there two things the batteries and the charger, can you try another charger ?
1. Batteries need replacing ?? make sure battery terminal connections are tight.
2. How long are you charging the batteries for ? i hear you say that's a silly question however you be surprised how many people charge their batteries for a hour then remove the charger.
3. Is the charger faulty ?
4. there is a remote possibility of a controller fault however this is not common..
In relation to the charger if you're in the UK, I offer a free testing service , you only pay the return postage...
Regards
Rob
www.gewizrepairs.co.uk
Feb 02, 2014 | Health & Beauty
Cmp2100 fault codes
what i do with a fault 12 please advice me
Jul 02, 2013 | Cars & Trucks
Indesit 123 FAULT F06
Sep 06, 2012 | Indesit W 123 Front Load Washer
My toshiba equium a200 does not charge even though the charger is plugged in. Is this a charger or a bettery problem?
This fault could be battery or charger related. As a matter of fact, it could be coming from both components too.
The simplest way to go about this is try using your charger on a compatible laptop or machine and see if it works. If it does, then you can be sure that it is coming from your battery.
On the other hand, you can remove your battery and try using it with another compatible machine. This is not very advisable as damage could be done to the battery in the process of removing and fixing it in a new machine again. It is best advised that you try testing it with a charger you have confirmed works properly.
Hope this was helpful? Please comment for more information and thank you for using FixYa.
Apr 20, 2011 | Computers & Internet
Please could you advise my Panasonic video recorder has a F06 error code and the cassette is stuck is there anything I can do?
You appear to have a K-deck mechanism. F06 means mechanism locks during unloading. The cause of which is the load motor and the carriage alignment. Which might explain the stuck cassette. If you look around the net for "Panasonic K Mech" you should find a load of free service information on it.
Mar 31, 2010 | Televison & Video
APC BR1500LCD Fault F01
This is a printout of the fault codes
System Fault indicator is on and all other
front panel indicators are flashing.
Internal UPS fault. One of nine Internal UPS Fault Messages is displayed:
F01 - On-Battery Overload F06 - Relay Welding
F02 - On-Battery Output Short F07 - Temperature
F03 - On-Battery XCap Overload F08 - Fan Fault
F04 - Clamp Short F09 - Internal Fault
F05 - Charger Fault
Nov 23, 2009 | APC BR1500LCD UPS System
Black and Decker Battery Charger
Fault Codes Meaning of Fault Code F01 Internal Shorted Cell Battery - Cannot be charged. Have battery checked by certified auto service center.
Excessive Load on Battery While Charging - Check load. F02 Bad Battery Connection - Check battery connection.
Battery Voltage Tool Low to Accept Charge - Have battery checked by certified auto service repair. F03 Internal Open Cell - Have battery checked by certified auto service center.
Sulfated Condition - Battery needs to be reconditioned. See manual. F04 Overtime Condition - Battery will not accept a charge after 18 hours of continous charging. Battery may have internal
damage. Have battery checked by certified auto center.
Battery Charge Rate is Set Too Low - Set charger to higher charge rate. See manual. F05 Overheated Condition - Disconnect charger and allow to cool for 30 minutes. Check for ample ventilation. F06 Reverse Polarity F07 Alternator Output is Out of Typical Operation Range
Operation Codes I=I=I=I Battery Reconditioning - (The letters DES will display for the first three seconds) I-I-I-I Alternator Voltage Check OOO Charger Standby FUL Battery Fully Charged
Sep 21, 2008 | Electronics - Others
Charging problem..
There is a Charging fault in your N95. It is advised to go for a repair. To charge your battery use UNIVERSAL CHARGER to charge it... You can find these kind of charger easily...
OR use another Phone to charge your battery...
Plz Rate Me.
Thanks.
May 11, 2008 | Nokia N95 Cellular Phone
Vehicle Parts & Accessories Logo
1,620 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
