Question about Home
I have an intertek infrared fireplace, model # imp-405-BR. it worked for a few times and now the master switch is the only thing that works, everything else stopped working any ideas?
Posted by Lori Smith-Thompson on
HEP1
Did you ever find a solution? I am having the same issue with the same heater.
Posted on Oct 26, 2020
5 Related Answers
catriver
Ron Marek
  • 878 Answers
SOURCE: freezer stopped working
Solomonau, it's hard to tell without being there exactly what is going on. I do know however,that in April of 2005 Samsung came out with a bullitin regarding the cap tube. It states that it has been inserted into the dryer incorrectly and can cause no cool situations. This is part of the sealed system which should be covered for 5 years. What you are describing sounds like a partial restriction, which could be taking place in that dryer and cap tube. If you were to post your model number, I would be able to tell if yours was included in this bullitin. You can then contact Samsung and inquire about this service bullitin, Catriver..post back.
Posted on Sep 20, 2006
Anonymous
SOURCE: swith wont work with charmglow fireplace
http://www.kenselectronics.com/lists/switches.htm
Your most likely using the wrong switch. Try the link above for the correct switch. Its a single pole 15A 125V rated switch. There are 3 terminals, the third is for the light in the switch and is a neutral wire for the indicator light only. The wires must be correctly on the terminals or else you'll create a dead short! On the link above your looking for the replacement of the ZE-215.
Posted on Dec 07, 2008
Anonymous
SOURCE: Charmglow Electric Fireplace ***NO HEAT** just lights up, HELP :(
Take the fan power switch apart and clean the 2 point contacts. Also clean the 4 male studs that the wires plug into. That should solve the problem.
Posted on Feb 13, 2010
Ronald Lockhart
  • 296 Answers
SOURCE: Moultrie I40 infrared not working
The ir gets power thru capacitors and inductors on main board.;check for loose connections, broker leeds; may have to replace ir array or main board to fix.Forget Moultrie having spares; try to buy used on as is from eBay.
Posted on Apr 08, 2010
Anonymous
SOURCE: Twin Star electric fireplace fan (maybe heater) doesn't work!
I have a twin star electric fireplace insert model #28efo24grs that is missing a remote any suggestions >>>>917-747-4893
Posted on Dec 06, 2010
I need a new power switch for a Intertek heater Model # ES3000, where can I find one
Here's a link for the entire control panel. http://energysaverheaters.com/ES3000-200CP.html
They do not sell just the power switch unfortunately.
Jan 05, 2017 | Heating & Cooling
Tip
Infrared RC Copters
Hi, everyone.
Ever since I saw the first advertisements on YouTube, some years ago, I wanted to acquire one of these little helis. When I finally acquired one, I had lots of fun until the little thing started to give me trouble.I own several of these mini-copters and have managed to maintan most of them in good working conditions for about 4 years now.
I would like to share some things that I have learned about RC Infrared Helis, specifically speaking, the airhogs RC helicopters.
First of all these little copters are not intended to be used outside home unless on a very calm day and on an area that has to be protected against sunlight, because sunrays interfere enormously with the IR beam with which the Infra-red light-emmiting controller communicates with the copter. I have found out that even while flying an air hogs copter indoors, when you get them close to a ray of sun shinning through a window, it suddenly drops to the ground.
Next, Most problems that I have encountered have to do with a combination of low battery power, plus trimming. In some of these copters, trimming can take a great deal of pulses before you can get them to fly right.
On the first models I would cut a cardboard fin and tape it to the front of the heli, below the nose and across form it, side to side to make it thrust forward.
Many times there were things like hairs or pieces of cobwebs attached to the axle of the back rotor, causing the heli to spin uncontrollably, even after trying to trimming it with the remote contol.
On other ocassions the copter wouldn't hold a charge even with fresh batteries on the controller. I learned that in time, the charger connector/plug may get dirty, so I usually spray the inner part of these connectors with a light coat of contact cleaner(available at any electronics store like Radio Shack) and then plug and unplug the connector a few times. This has worked fine with my older copters that have presented such problems.
on Sep 26, 2011 | Silverlit Toys Red Air Hogs R/C Havoc Heli...
I have a vermont castings radiance 2600 fireplace, the pilot light is lit but the on switch isn't turning the fireplace on
desa is out gone but maybe pro com have a controller with the same controls as the desa check #on the control and see cross ref in Google search they can be 80.00 and up but can b found
Dec 10, 2013 | Rinnai Desa Vent-Free Infrared Gas Heater:...
I have a Amish looking electric fireplace, Model FL18-r, which has quit heating altho the fake flames still work. I am trying to see if the heater insert can be replaced, where and for how much, or...
There are a couple of reasons the heating unit part of the fireplace stop heating. A dust and lint build up in the heating coils can cause them to burn out. The heater overload circuitry has shut the heater down or has failed or the unit needs to reset. so lets go to the easiest thing for you to do, yourself.
RESETTING THE HEATER
Turn the Master ON/OFF Switch to OFF. Unplug the fireplace and wait 12 - 15 minutes before plugging it back in. Then turn the Master ON/OFF Switch to ON. Turn ON each individual function of the fireplace, one at a time. If the unit was able to reset itself, each function should work normally. If it doesn't, then one of the issues I listed above is the problem.
If your fireplace is less than one year old, it should still be under warranty. So contact the manufacturer (you can find the contact info in your Owners Manual) about repair or replacement.
One personal aside: None of the electric fireplace/heaters on the market today, have a long trouble free life span. Usually, it's 9 months to a year, when consumers start having problems. I sold these type of appliances for a couple of years, as an adjunct to our gas fireplace and heater business. When they started to become a problem for our customers, we quickly realized, that no matter who the manufacturer is/was, they are not what they are touted to be and we discontinued selling them. It's been 4 years since we discontinued selling them and apparently, nothing has changed in their manufacture. As, I answer more than my share of questions about them, here on FixYa. As one person told me, "I wish I had bought a vent-free gas fireplace instead. It would have cost me more, but would have been more reliable and would still heat, even if the power was out."
I hope this helps you trouble shoot and solve the problem.
Happy Easter!
Apr 23, 2011 | Heating & Cooling
My customer just bought a CS 1205 from our True Value Store. The blower on the new CS 1205 does not work. It has been used three or four time. The flame comes on however. What do you suggest?
Before call Dimplex Technical Service (888-346-7539) have your customer turn the Master ON/OFF Switch to OFF. Unplug the fireplace for 12 - 15 minutes. Once plugged back in, have them turn the Master ON/OFF Switch to On and then turn ON each function of the fireplace one at a time. If everything is performing as it should, the unit reset itself. However, if this becomes a recurring problem, they should contact Dimplex Technical Service.
Hope this helps you solve the problem for them.
Apr 05, 2011 | Dimplex CS1205 Electric Compact Heater
Cant get my dimplex club electric fire to come on
Do the rest of the functions of the fireplace work? If so, turn the Master On/Off Switch to OFF and plug the unit for 12 to 15 minutes. After the time has elapsed, plug the unit back it and turn the Master On/Off Switch to ON. Then turn on the flame function switch. Hopefully, that timeout allowed the unit to reset itself and the flame function is now working. If it isn't, either the flame function switch is faulty or the circuity to the light bulbs and the ro-tater motor that turns the shaft, that he bulbs are attached to, has failed. Without knowing how old the unit is and how much use it's had, it's hard to pin down one thing that is causing the problem. If it's any consolation, you are not alone. Hundreds of these electric fireplaces (all makes & models) fail every year.
If all else fails, contact Dimplex USA, Technical Service at 888-346-7539.
Hope this helped to solve your problem.
Mar 17, 2011 | Heating & Cooling
Our dimplex electric fireplace model number 28106D3F shut off and won't turn back on
Turn the Master ON/OFF Switch to OFF. Unplug the fireplace from the wall receptacle and leave unplugged for 10 - 15 minutes. This will give it time t reset itself. In the future, if you finding you're have to do this more often. Unplug the fireplace, stop using it and call Dimplex USA Technical Service 888-346-7539 for further instructions.
Mar 09, 2011 | Heating & Cooling
Problem lighting gas fireplace
my fireplace lights up for a short time and goes out after 5 or 10 minutes, please help with this problem.
Dec 08, 2009 | Heating & Cooling
Can't switch on
hi try this: take a small flat (watchmaker) screwdriver open the battries cartige an look for the springs that connect and holds the battries shive the screwdriver between the last coil of the spring and extend it (for better connection) check with brand new battries look inside the inlet ac adapter and look for a little silver tab shove the screwdriver inside and make some distance from its position (for better connectin) check with the ac adapter if that didnt worked then check the play button - maybe it got bad connection open the cd player look at the play button - there is rubber between the button and the board clean the connection with borad with some alcohol assemble it all toghter and see if good NO?? sounds like one of those "ghost in the machine" thing GOOD LUCK
Mar 29, 2006 | iRiver iMP-450 SlimX Personal CD Player
Home Logo
251 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
