Question about DISH Network Televison & Video
What tv input should I hook up my dish network on?
Posted by Amanda Stevens-Brill on
vince
  • 1,234 Answers
HDMI 1 if your going to be watching it more than other programs or HDMI 2 if you have cable and spend a lot of time on it. Personal preference is 2.
Posted on Mar 06, 2018
5 Related Answers
Anonymous
SOURCE: no signal when hooking up to dish network.
I unhooked the new tv and hooked up the old one to see what channel it was on and then rehooked up the new tv and put it on the same channel as the old one.This worked but I also had to put the cable into the hook up on the back marked cable instead of the one marked HDTV.
Posted on Dec 12, 2008
Jim Franks
  • 374 Answers
SOURCE: adding tv to a dish network dvr
Your upstairs tv is connected via a coaxial cable and you can do a few things to get programming to the third room.
The first is to locate the wire that enters the upsairs room that currently has tv and insert a splitter by cutting the line to that room and running the out ports to the rooms and the in port to the other end of the wire that you cut. This will give you the same picture in both rooms.
If you have a system that does not use diplexers to backfeed the second TV you can backfeed the 3-4 cable going to the TV1 by cutting the line and adding a splitter with the inport running to the 3-4 port on the receiver and one of the out ports going to your tv1 and the other outport going into the UHF side of a diplexer. You will need to cut the Satellite feed into the back of the receiver on the back side of the seperator and connect the seperator to the SAT port of the diplexer. The IN/OUT port of the diplexer will connect to the end of the sat feed cable that goes to the wall plate. This will allow you to go into the attic of outside of the house and find the sat cable that feeds the TV one and break it there and put the IN/OUT port of that diplexer facing the TV1 room and the SAT port connecting to the other end of the cable you broke. The remaining UHF port will be the feed for the new room that you wish to connect. This set up will allow for viewing the same program as that at the TV1 location however you will need to change the channels at the TV1 location or buy an IR to UHF converter to allow you to be able to work the system independently from the receiver. Hope this answered your question. IF you need further assistance please contact me and thanks for using Fix Ya.
Posted on Dec 31, 2008
gtaplytmpt
Andy
  • 90 Answers
SOURCE: Hooking a Wii to Dish Network reciever(not a hd tv)
It sounds like you have a pretty new TV. This means that there should be multiple AV jacks in the back for setting up your many components. Plug in the receiver into #1, the Wii into #2, and any other equipment you may have (DVD, VCR etc.) in the same way. You should then use the original TV remote to switch between Video 1, 2, 3 and so one for each compnent you want to use. The button on the remote will be labeled video, tv/video, input select, or input, something like that.
Hope this helps!!
Posted on Jan 02, 2009
Anonymous
  • 118 Answers
SOURCE: hooking up a dish network to my tv
Well, I don 't have that T.V. but I can tell you that you may have to go to your menu and look for your channel setup and change it to another channel output. If that doesn't help then have it search for channels.
Posted on Jan 30, 2009
Anonymous
  • 151 Answers
SOURCE: Dish Network connection and surround sound
HI, connect audio output from tv to system,you may have to turn this on or turn up in tv menu for some sharp tvs,this should get sound for tv and dvd and anything else you hook up to tv.
Hope this helps.
CABLE GUY.
Posted on Mar 29, 2009
I have Dish Network with the Hopper. My reviver has a HDMI slot and hooked mt Roku but cannot find how to switch the "input" to what Netflicks. Ugh, been at it for hours!!
Use your TV remote "input" "source" or "tv video" input button. If using the.Dish remote press the clear tv button then input. Repeat to go back to HDMI. Make sure you press sat to change channels once you get back on the HDMI input for dish
Oct 05, 2014 | DISH Network Televison & Video
Hooking up a Coby tv 32" to dish network but it says no signal
"No signal" usually means you are on the wrong input. Look at the back of the TV to determine what plugs were used to hook up the Dish box, it will be labeled nearby (like Video 1, Component 1 or HDMI1). Now find the "Source" or "Input" button on the TV remote (it can also be found on the TV) and set it to the input the Dish box is plugged into.
If you are using the Coax cable (the kind that screws on), go into the menu of the TV and run a "Channel Search/Scan". This will find the channel the Dish box needs to be set to on the TV.
Let me know if this doesn't work.
Jan 14, 2013 | Televison & Video
I have a 322 dish receiver there is just too ports to hook to and i have ant.+ cable and sat. to hook to it anyhelp would be welcome. thanks
Heychuck68102, my name is Mike Houston of DISH Network and I was going over yourpost and I see where you want to connect a cable wire plus you're satellite. Ifyou have a TV that will allow for a RCA connection you can run the RCA cable tothe top red, white and yellow inputs and run the antenna directly to theTV/Antenna IN. Then you will be able to connect the cable to the TV CH ¾ input.I will send a link to help with these steps, http://www.dishnetwork.com/SupportSection/how-to-set-up.
Apr 16, 2011 | DISH Network 322 DTV Receiver
How would I be able to hook up surround sound to my TV and Dish Network
Take the cable running from your receiver to the TV and run it from the receiver to the amplifier input. Next you want to run a cable from the amplifier to the TV. Make sure you set the inputs on the amplifier and tv correctly so you get both video and audio.
Daniel Busa
DISH Network Customer Service
Dec 19, 2010 | RCA RTDVD1 System
How do u hook up the dvd player and dish network to your tv
If you have HD TV it is best to hook up the DVD player separately.
The easiest way to connect your DVD player with your TV, is to find the cable going from the receiver to the TV and disconnect it from the TV.
Connect this cable to the back of the DVD player where it says "in" or "input".
Next take another cable and connect it from the DVD player output to the TV. Once you've done this make sure your TV set is tuned to the proper input or source. Your DVD's should play when the receiver is off, however, you'll probably need your DVD player on to get the DISH signal.
Daniel Busa
Dec 10, 2010 | Sanyo DWM400 DVD Player
I have Dish network. I want to record TV onto the VCR, but cannot get channels to record. i can playback videotapes and the record works, but cannot figure out how to get the signal to record.
The output of the Dish Network box should be hooked to the input of the VCR.
The output of the VCR should be hooked to the input of the TV.
The VCR should be on channel 3 to record. Select channel to be recorded on the Dish Network box.
It sounds like you have Dish Network box output hooked to TV input.
& VCR output hooked to an aux. input on the TV.
Nov 28, 2010 | Quasar VHQ401 VHS VCR
I am on dish network, how do i hook up vcr to tv
What does Dish have to do with VCR?
Hook VCR to an input on the TV.
Most likely it will be with a coax cable or a three wire - video / audio harness.
Dec 29, 2009 | Televison & Video
No TV signal
If it's hooked to Dish network, you have a receiver to connect to the TV. If you're using the receiver's RF output on channel 3 or 4 to the TV's antenna jack, you need to have the receiver on while the TV is scanning or it won't add the receiver's output channel. You can rescan channels after you turn the receiver on. If the TV has AV input jacks and you're connecting the receiver that way, you need to switch the TV to the AV input. That may be difficult or even impossible without the TV remote.
May 04, 2009 | Televison & Video
Hope this helps.
CABLE GUY.
Mar 29, 2009 | Audio Players & Recorders
Hooking up tv to dvd player
You will probably have to use your tv remote and change the input for your dvd. It's usually video 1,2 or component 1,or 2
Jul 01, 2007 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
48 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
