Question about Karcher Garden
The discharge pressure on my Karcher electric pressure cleaner varies. When low no cleaning can take place. How can I fix?
Karcher Model 2.26 MR.
Posted by bradknipper on
  • Karcher Master
  • 18,378 Answers
Karcher 2 26M Parts List and Diagram 16016020 eReplacementParts com
There are videos on the site that show how to troubleshoot this. The issue is most likely a valve that is sticking open sometimes.
Posted on Mar 05, 2018
5 Related Answers
Martin Grech
  • 94 Answers
SOURCE: Karcher electric pressure washer
Dear mike husband,
One reasin for this fault could be a damaged lance or turbo lance. Try by replacing with new ones. If the problem is not solved, then the fault is due to a damaged spill valve. The spill valve could easily be damaged by using not suitable chemical or detergents. After using chemical detergents, one must always rinse the machine by passing pure water. The spill valve could also be damaged by leaving the machine for a long time with pressure in the system. One must never store such machines with pressure still inside. Always press the gun before storing.
Well the solution is to change the spill valve with a new one. In some cases even faulty suction valves can give this problem. But in the majority of cases it is the spill valve.
If you do not know how to fix this problem, it is better to be done by an expirienced technician.
Regards,
MG.
Posted on Nov 05, 2008
Anonymous
  • 104 Answers
SOURCE: Karcher K 3.68M Electric Pressure Washer. Wand trigger Locks Up.
Sounds like the pressure valve is broken thats why you cant depress the trigger , the valve is on the pump , i would suggest taking it to a repair shop as they are fiddly things to fix
Posted on Jun 05, 2009
Anonymous
SOURCE: Karcher K 2400 HH Pressure Washer no pressure
http://www.landanorthwest.com/documents/instructional/spill_valve_instructions.pdf
Anonymous
SOURCE: Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Posted on Oct 03, 2009
Anonymous
SOURCE: I have karcher 620m pressure
Try this. While pushing the trigger of the gun, turn lance fully anticlockwise and then turn back fully clockwise.
Posted on Mar 26, 2010
My Karcher MX720 pressure cleaner keeps tripping the mains power.
Jeff, the specs say it is 230 volt, 16 amp minimum, start up would be more, probably minimum 20 amp.or larger, check your manual. Are you using a small gage/ low capacity extension cord this could blow a breaker or may have an internal short have checked by a Karcher repair center. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Any idea why my new 13 amp pressure washer is tripping 15 amp circuit...
http://www.garagejournal.com/forum/showthread.php?t=203916
http://www.electriciansforums.co.uk/electrical-forum-general-electrical-forum/54098-problem-pressure-washer.html
Jun 17, 2016 | Karcher Garden
I have no pressure and the pump surges when i release the trigger on my electric karcher modle k 2.360
If you have a Karcher then you should always post your machines barcode.
Because you have the low pressure and pulse this will be the valve block. Your machine has 3 piston and each has 2 valves (inlet and outlet). Because you dont have the barcode, i cant be sure if you will buy a valve kit of 6 valves or a pre-assembled manifold block.
it could be this machine and spares :
http://www.sparesgiant.com/cleaning-equipment/pressure-washers/karcher/k-series-parts/k2-range/k2-36m16724300/
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Sep 01, 2013 | Karcher K238CCK 1600 PSI 13 GPM Electric...
Will not **** soap or universal cleaner up
Make sure that there is any bloackages in the suction or the end filter is blocked. Also make sure that your lance is set to mix/ low pressure.
Jan 18, 2011 | Karcher FactoryReconditioned 1400 PSI 13...
My Kärcher K2.080 pressure cleaner (1450psi /
According to my search, Karcher has a 2 year warranty on this product. If you can get the serial number and model number off of it. They should be able to identify when it was made and then can honor that warranty. Otherwise the pump seals appear to be damaged by your description of the problem. Hope I've helped.
Best, Mark
Dec 28, 2010 | Karcher Electric Cold Water Pressure...
Getting the cleaner into the system
You will need to adjust the lance on the end by twisting the end of the nozzle. This way the machine draws chemical at low pressure.
Jun 22, 2010 | Karcher K 5.85 M Electric Pressure Washer
Karcher 620m runs but will not pump water
The pump that connects to the motor could be bad/and or loose
May 10, 2009 | Karcher 2500 PSI Pressure Washer
Cleaning ice tea maker
Try to do that
  1. Pour 1 quart (32 oz.) of undiluted white household vinegar into the water reservoir.
  2. Place the pitcher lid on the pitcher. ...
  3. Push the "on" button to begin brewing cycle. ...
  4. Re-plug the cord. ...
  5. When your machine shuts off, unplug the cord, remove the pitcher.
Feb 24, 2009 | Sunbeam Mr. Coffee Iced Tea Maker, TM3PS...
Repair to old Karcher steam cleaner
q services settle north yorkshire.
01729825656
damian thats me
07970636222
Mar 13, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
62 people viewed this question
Top Karcher Garden Experts
Martin Grech
John Trevino
Bruce Robin
Are you a Karcher Garden Expert? Answer questions, earn points and help others
