Question about Johnson Boating
Hi i have a 1984 25hp johnson with a miss, and a kick like a horse.compresson exellent new plugs and coils. thanks
Posted by eric pryor on
Gary F
    Sergeant:
  • 236 Answers
Spray clean the carb(s). Put in fresh gas and oil. Run Johnson cleaner in tank of gas.
Posted on Mar 17, 2018
2 Related Answers
Coldcut
Karl Whisenand
  • 1554 Answers
SOURCE: Fuel prob?
By the way if anybody see's you they may wisecrack
but the sound of a clean spark
its priceless.
Posted on Jun 11, 2008
emissionwiz
Marvin
  • 85239 Answers
SOURCE: Hi guys...ford bantam 1.3i rocam motor...bakkie
What year??
Posted on Dec 24, 2014
I have a 45 johnson sea horse outboard engine that just shut off while driving it and wouldht start up again .but it started up fine the next day what could be the problem?
Could be fuel or thermostat ... if the water isn't getting to the motor when it needs to cool it will stall .. Usually takes 10 min or more of its partly plugged with sand or debris. Remove thermostat and flush... some have two thermostats.
Aug 22, 2018 | Johnson Boating
2011 clubman, has new plugs .Still missing acts like turbos don't kick in ?
CHECK COIL OR COILS FOR SPARK ON ALL PLUGS INDUVIDUALY. OR LEADS IF THIS CAR HAS THEM.
Feb 13, 2018 | Cars & Trucks
What is the proper gas /oil mixture for a 1979 Johnson sea horse outboard
Hi Paul:
My old Evinrude called for 32:1 and they were second cousins.
I'd bring spare plugs and a wrench as part of my "kit" if I were running an engine that old.
Better to run extra oil and not break it.
Cheers.
Mar 14, 2016 | Boating
Misfire coil
coil pack voltage may be good but coil may not be putting out voltage check with spark checker.also fuel injector may be bad if all good do compresson test on cyl
Apr 16, 2014 | 1998 Ford Expedition
What type and weight of oil for johnson 28 horse outboard boat moter
Hi, mix the gas and oil at 50 to 1 and use two cycle outboard oil. Regards Phil.
Jun 29, 2012 | Seloc Johnson Outboards 2002-2007 Repair...
Replaced both coils replaced cid module but motor still has a miss while idleing and when given gas to run backfires and misses terribly. it is a 1993 johnson 30 h.p. elec start. what am i possibly...
check the timming first. have you changed the plugs, i just buoght a new set and one plug died 13 mile off shore. goog thing i keep the old ones onboard.
check you plug wires too. the omc are put together style and sometimes will vibrate apart at the ends.
Oct 13, 2009 | Light Outboard Motor Boat Bass Fishing...
2003 ford expedition , missing while accelerating
most likely cause is a defective ignition coil, there is one for each cylinder (coil over plug), the dealer will have to test it to determine which of the eight coils is the source of the miss. the coils are about $60 each
May 20, 2009 | 2003 Ford Expedition
Boating Logo
Top Johnson Boating Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Johnson Boating Expert? Answer questions, earn points and help others
