On the box or in the manual there should be some information on that subject .in there it should tell you what w eight it needs. You would go to a smoke shop and ask to see the weight for caliberation .they will know what you need .so get one and on the setting and it should have a button that says CAL PUSH IT THE SCREEN SHOULD START PLASHING WHEN IT STOPS SET THE weight on it and when it re ads the correct amount then your all set .hope this helps you
SOURCE: weight watcher scale not calibrating weight correctly
Press the scale once with your foot. All screen options should display to initialize and then go to 0.0. Now step on the scale. It should read out your correct weight. If not, first remove and replace the battery for reset. If still not, replace the battery. If still not it's ready for return or replacement. Hope it works! Dave - CA
SOURCE: Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
SOURCE: HOW DO I RESET A WEIGHT WATCHERS DIGITAL FOOD SCALE?
www.weightwatchers.com/.../1108-usa-revised_booklet...Try this connection . It should give you a good start.
Hi Debbie Panopoulos, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
do you mean re zero the scales ?
or do you mean alter the points to the new points system ? (which can't be done - new scales needed )
If you get stuck ring weight watchers and ask them the question.
