Question about Photography
HOW DO I THREAD THE FILM IN? - Photography
Posted by Bobbie Chan on
Tony Parsons
  • Photography Master
  • 6,301 Answers
Easiest way is to follow the instructions in the camera manual. If you tell us which camera you are using, we may be able to offer more detailed information. BTW, there is no need to shout.
Posted on Oct 26, 2018
How do I reload new film
Open the camera back.
Put the cassette in the film chamber.
Pull out the end of the film leader, and take it over to the take-up spool.
Thread it onto the take-up spool as per the instructions in the manual.
Close the camera back.
Wind on until the counter shows '1'
Take your photos.
Jan 01, 2017 | Photography
How do you load it
To open back cover lift knob on top of camera ( this knob has a small arm that unfolds - used in rewinding).
Once open you will see which side is the film side ( under this knob) and the take up side. On the film side raise the knob again in order to insert film case, the top of this should flip over later used to rewind film. with film trail out toward back of camera. Now push the knob down. Film should only be loaded one way so the knob can be lowered into film canister. Lower knob and Film canister is now secure.
Next thread film leader onto take up spool. Some times these have a slot , but most Just have the teeth that fit the film edge.thread the film into slot then unto teeth. You will need to use film advance arm (There should be an arm on the top opposite side of film knob) you would move that would advance film.
as you move this arm ( with cover open ) film holes should engage the teeth on bottom and top. ( if you can't advance after 1 or 2 advance arm swings) press take picture button ( releases springs).
continue until film is captured top and bottom. Use the film spool knob gently wind film back into canniester until snug don't over wind. Close cover, take a picture with lens cap on, repeat that. As you wind ,the film cartridge knob should rotate.
You are not wasting pictures film was designed for this waste.
you should know how many photos were on film 12/24/36 pictures.
you may have a knob to set to that number.
When your ready to remove film ,push silver button on bottom and use winder handle ,rotating until free and easy. Open cover mention earlier.
wow can't believe I remembered all that and hope that helps.
Sep 23, 2016 | Photography
Film is not developing
There is not any in camera developing. This is not a digital camera it is a film camera wherein we put a film cartridge with a specified number of shots into the camera then thread the film leader to the takeup spool, close the camera advance the film a few frames, then we are ready to shoot. After the specified number of shots, 24 or 36, film is rewound into the canister, camera back opened film canister removed then taken to the lab for processing.
Oct 04, 2012 | Pentax ME Super 35mm SLR Camera
Bell and Howell 16 mm diagram . don't know how to thread the film
Check this Website and see if one of the manuals doesn't give you the answer:
http://www.paulivester.com/films/projector/BH273man.htm
Jul 02, 2017 | Bell & Howell Photography
Film problem for my holga
Black film as in underexpose, after you have them printed?
If you open a roll of 120 film:
Remove the little tape holding to the film.
Place film onto Film Spool Studs.
Pull film out from film leader and thread to Take Spool.
Turn until Arrow Line on film aligns with Start Mark of Film Holder.
Close film cover or back.
Advance camera to Zero (0). Now you are ready to shoot.
Just rememer what film speed your are using.
Hope they are helpful.
Truly,
[email protected]
Dec 31, 2008 | Holga Flash, 120 Medium Format Camera...
Kodak moviedeck 475 Film won't thread
There is a small plastic gear that disintegrates with age on these units. The gear is worn and cannot turn the larger gear to thread the film. Good luck finding parts. There is one place that sells parts but I think they gauge the public
Oct 15, 2008 | Kodak Cameras
I have a leica A camera and I'm not sure how to thread and roll the film (load the film). Please help.
search You Tube for loading Leica threadmount cameras - there's a video of the whole process
Aug 22, 2008 | Leica Cameras
Photography Logo
301 people viewed this question
Top Photography Experts
Marvin
Marvin
Tony Parsons
Tony Parsons
Are you a Photography Expert? Answer questions, earn points and help others
