2000 Toyota Camry Logo
Posted on Jul 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
00' Toyota Camry -- Radio Issues
My Camry is a previously owned vehicle, known to have been in at least one accident (rear right bumper). The radio has never worked correctly since I started driving the car four years ago.
Most of the time the CD player skips the disks I try to play. It is apparent that it is a problem with the stereo given that the skips coincide with bumps in the road. Sometimes it is only with the large bumps, but others it will be with every small object, making it nearly impossible to listen to. Every now and then a CD will play fine but usually it skips, giving me the impression of a loose or damaged wire.
Also, the radio will act up otherwise every now and then as well. Most of the time it is the volume button -- it will turn the volume up when i turn it down and vice versa. Also, one time none of the buttons would respond, even the power button. I had to restart my car for it to go back to normal. Oh yes, and the tape player has never worked. All this sounds electrical to me, but since I have not tampered with car wiring before I would like some opinions, please!
So, does this sound like I should check the wiring, replace the stereo, or replace everything? If I should check the wiring, please let me know if this is something a typical amateur could do themselves or if it requires certified mechanics. Any links for instructions would be appreciated. THANKS!!
Anonymous
Level 2:
  • Expert 154 Answers
  • Posted on Aug 08, 2009
Anonymous
Expert
Level 2:
Answers
154
Questions
0
Helped
74391
Points
281
YOU NEED A RADIO. CK EBAY OR AFERMARKET.. CALL DEALER ACK WHAT I COST TO SEND RADIO OUT
2001 toyota camry rear speakers don't work
It is possible the radio has failed, either speaker power or fader circuit. Substitute for one of them a known good speaker, and see if it works or not. You can buy one cheaply from Parts Express or similar if you cannot find one in the garage. That will tell you if both speakers have failed (very unlikely) or it is the radio.
04 toyoya camry radio wireing harness pin
Hi there:
According with the diagram on 2004 Toyota Camry Car Radio Wiring Diagram...
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink/Blue
Car Stereo Amplifier Location: Located to the right of the glovebox behind the passenger side of the dash.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Left Front Tweeter: Powered by the same wires as the left front speaker.
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Right Front Tweeter: Powered by the same wires as the right front speaker.
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Tehy could be harnesses 15 or 20 pins, try to look your right replacement in this links:
- 2004 Toyota Camry Stereo Wiring Harness
- 1990-2013 Toyota Camry Auxiliary Car Audio Input Adapter Kit
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
1helpful
I need the wiring colors for a after market radio harness for a 1997 toyota 4runner withe the premium radio
here to your 1997 Toyota Camry. Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Illumination Wire: Dark Green
Dimmer Wire: White/Green
Antenna Trigger Wire: None
Front Speaker Size: 6 1/2′
Front Speaker Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Green
Right Front Speaker Wire (-): Blue
Rear Speaker Size: 6′ x 9′
Rear Speaker Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
2helpful
2answers
I HAVE A 1990 TOYOTA CAMRY AND I NEED A WIRING DIAGRAM FOR RADIO INSTALLATION.
does this help, or do you need more?
1990 Toyota Camry Car Stereo Radio Wiring Diagram
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Black/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 3 1/2?
Front Speakers Location: Dash
Right Front Speaker Wire (+): Light Green
Rear Speakers Size: 5 1/4?
Rear Speakers Location: Rear Deck
4helpful
Need a wiring diagram for a 2003 toyota camry with jbl audio system
pls rate
3helpful
Need wiring diagram for 99 Toyota Camry stereo
2helpful
2answers
Audio wiring problem
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown (or your own wire to a metal grounding point)
Illumination Green
Antenna Trigger Black/Red
Front Speakers 4" Dash
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Green
Right Front (-) Blue
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
I a '83 camry, there are 2 seperate plugs that go into a factory radio.
One for Power/and front speakers, and the other for rear speakers.
Sounds as if you are missing part of the harness for the rear speakers (or it is shoved in the back of the dash unused by the previous install). If there is not an un-cut plug in the dash - your only course of action would be to run your own set of speaker wire to the rear.
See this picture... these are the plugs that should go into your factory radio....
Metra kit 71-1938 will go from your factory wiring directly into your factory radio.
Thanks for using FixYa - a FixYa rating is appreciated for my effort in answering this Freebie question.
1helpful
4answers
Toyota radio code
Johnny5486:
Emissionwiz is correct, but, his information is for older Model Camrys.
The 2003 "factory-installed" radios in the Camry product line does not have an anti-theft feature, and, because of having no anti-theft feature, there is no reactivation code. If you have a dead battery, the only thing you will lose regarding the radio functions would be the radio stations that you programmed into the memory. The radio will function properly after a dead battery is replaced with no issues.
1helpful
2answers
Radio/CD player Wiring
Here are the correct factory radio wire colors with definitions.
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Green
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Side Panels
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
