Question about Denon Audio Players & Recorders
Denon avr-600 receiver flashing protect. speakers not the problem. how to reset microprocessor. no manual available.
    Top Expert:
  • Denon Master
  • 30,806 Answers
Repair the damaged amplifier/power supply first. There is no 'reset'.
Posted on Mar 04, 2018
5 Suggested Answers
Anonymous
  • 1067 Answers
SOURCE: Denon AVR-1905 remote
www.remotewarehouse.com grenteeed fit match
Posted on Jan 26, 2008
Anonymous
SOURCE: Denon AVR 900
well its possible you have it on stereomode put it on prologic ceneter mode on normal for best sound
Posted on Nov 05, 2008
Anonymous
SOURCE: Denon AVR-1508 Receiver problems - cuts off and goes into protect mode
i have the same problem . denon had changed knob and circuits ?! one day later ... same issue !
i have 5.1 evo tangent 4-8ohms and 2 technics 8ohmsand i use frquently A+B configuration
Posted on Nov 08, 2008
Anonymous
SOURCE: compatable receiver list for Bose 901 series VI
I contacted the Customer support folks at Bose. Here is what they said: With a stereo receiver, the equalizer is run through the tape monitor section in the back of the receiver. The receiver's tape monitor output, left and right, runs to the amp input section of the equalizer, left and right. Then the amp output section of the equalizer, left and right, runs to the receiver's tape monitor input section. With a surround sound, home theater, type of receiver, the theory is the same, but the connection is through the preamp-out/ main amp-in section of the receiver. Not all receivers have this feature. Most, in fact, do not. Check the back of the receiver. There would be a connection made by two U-shaped clips. The plugs would be pulled out. Then connect from the preamp-out to the equalizer's amp input section; and from the equalizer's amp output section to the main amp-in. This effectively isolates the equalizer so that it is not affecting the other speakers in the system or the receiver's surround processing. Attached is a current list of known 901-home theater compatible receivers:
Note: Specifications subject to change without notice. Bose Corporation is not responsible for any inaccuracies due to manufacturer changes. Inclusion in this list does not indicate an endorsement by Bose Corporation. When in doubt contact the manufacturer of the equipment.
I have the list in a pdf document but do not see a way to attach it.
Contact me at [email protected] and I'll forward the pdf.
1-30-2009
Posted on Jan 30, 2009
mattvierra
Matt Vierra
  • 75 Answers
SOURCE: Denon receiver AVR-3300: Unstable source selection
Very important you have run system set up menu it configures your receiver with inputs analog or digital,speaker size,input,room correction etc Different input modes can be selected for the different input sources.
The selected input modes for the separate input sources are stored in
the memory.
q AUTO (auto mode)
In this mode, the types of signals being input to the digital and
analog input jacks for the selected input source are detected and
the program in the AVR-3300’s surround decoder is selected
automatically upon playback. This mode can be selected for all
input sources other than PHONO, MD/TAPE and TUNER.
The presence or absence of digital signals is detected, the signals
input to the digital input jacks are identified and decoding and
playback are performed automatically in DTS, Dolby Digital or PCM
(2 channel stereo) format. If no digital signal is being input, the
analog input jacks are selected.
w PCM (exclusive PCM signal playback mode)
Decoding and playback are only performed when PCM signals are
being input.
e DTS (exclusive DTS signal playback mode)
Decoding and playback are only performed when DTS signals are
being input.
r ANALOG (exclusive analog audio signal playback mode)
The signals input to the analog input jacks are decoded and played.
t EXT. IN (external decoder input jack selection mode)
The signals being input to the external decoder input jacks are
played without passing through the surround circuitry Your remote is searching for inputs because you did not properly run system set up!!! Here is a link to your manual [PDF] AVR-3300/1 3.3E*
Posted on Jul 22, 2009
Denon AVR-1513
disconnect speakers then try again if still shutting down you will have bad outputs.
Aug 26, 2014 | Denon Audio Players & Recorders
Denon avr-1612 keeps shutting off and on
You have an output problem, check outputs for short
Apr 07, 2014 | Denon AVR-1612 5.1 Channels Receiver
I moved and set up my AVR-1082. I hooked up the DVD and it showed the video through my Sony TV. I shut it off and hooked my speakers up. I think when I did that I must have hit something on the front of...
Reference to the manuals is highly recommended. All controls and indicators are explained. There may actually be a clue on the front panel. Resetting the microprocessor is a last gasp solution and may only bury you deeper because it will zero out all settings.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-1802-Receivers-manual/id/363bh839/t/2/
Page 43
Jun 05, 2011 | Denon AVR-1082 Receiver
How do I restore factory defaults on my Denon AVR-2809? I can't see it in the manual. Thanks
Register and download the USER GUIDE (10.6MB) for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-2809CI-Receivers-manual/id/21864dj590/t/2/
Page 60
Resetting the Microprocessor
Perform this procedure if the display is abnormal or if operations cannot be performed.
When the microprocessor is reset, all the settings are reset to their default values.
1 Turn off the power using <POWER>.
2 Press <POWER> while simultaneously pressing
<STANDARD> and <DSP SIMULATION>.
3 Once the display starts flashing at intervals of about 1
second, release the two buttons.
Mar 30, 2011 | Denon Audio Players & Recorders
How do I reset my Denon avr-589? I would like to reset my reciever back to original settings.
Press the power button, and speaker a and speaker b simultaneously and hold until the display begins to flash then release speaker A and speaker B buttons. That resets the microprocessor.
Jan 02, 2010 | Denon AVR-1508 Receiver
Denon avr 885 it automaticallyshuts off when i try to power it up
Its possible that the Receiver is going into protection mode and possible some speaker cable might have touched the body or with each other.
Remove all inputs and outputs and then restart the receiver. If it starts then you are lucky. Connect all cable and wiring properly and ensure that they do not touch each other. You might have to reset the microprocessor also.
If the problem persist then let me know to further the trobleshooting.
Please do rate this solution and thanks for using FixYa.
Mar 06, 2009 | Denon AVR-885 Receiver
AVR-600
The problem is past that point once the protect continues to activate the amp is in need of service
Feb 25, 2009 | Denon AVR-600 Receiver
Denon AVR 1506
Try this, turn off the unit and remove the AC power cord from the electrical outlet, Hold the AUTO button and PCM button and plug the unit back into the electrical outlet, if the display starts flashing with 1 second intervals then release the 2 buttons, this initialized the microprocessor
Feb 09, 2009 | Denon AVR-1506 Receiver
My denon reciever display wont't work
I read something the other day in the user manual about re-setting the microprocessors if the display doesn't display properly. Turn the amp off.  Hold down the input mode & analog buttons while turning power on. The whole display should flash on & off at 1 sec intervals, then release the two buttons. This resets the microprocessors & supposedly fixes display problems.
Jun 23, 2008 | Denon AVR-2805 Receiver
139 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
