Question about Sony Televison & Video
Sony kdl70w850b red light flashes 4 times
After turning on and for a minute tv stays on from 1 minute to 5 or more hours then shuts down and red light flashes 4 times just tried something i found on a sony blog another person with my same problem took settings off vivid video setting and it stopped doing it, its been 24 hours almost and mine is working ok for now, does anyone know what bought this would be
Posted by vincent colan on
  • Crissie williams Aug 04, 2019
    Is there a video how to get to that setting??
Larry
  • Sony Master
  • 2,800 Answers
The unfortunate part Mike Miller is a lot of people doing videos on youtube on how to repair sets really don't know what they are doing and sending people in the wrong direction with bad answers, they have something that fixed their set and think that is the only part that would cause the issue or causing parts to be ordered that aren't bad....here is what you do to diagnose your TV...I pulled my service manual for your set and this code is from a backlight dimming error, there are 2 things that would cause this, 1st is the LD board is bad and needs replacing...I have a link at the bottom for a new board from shopjimmy.com...2nd would be some bad LED lamps in the panel and its shutting down the PMW (pulse width modulation) signal and turning off the LD board (chances are this is what is happening as that board seldom fails)...if your able and feel comfortable doing it you can measure the voltage at the PMW pin on the power board...it should show between 3.5 and 5 volts depending on what setting the backlights are set at...If you see that voltage when you power the set up and its running but it goes to nothing when the set shuts off then its lamps.. Most likely you have a couple failed lamps in the panel as of now but more will burn out if you don't get it fixed and the run time will get shorter and shorter as more of them fail over time..if that voltage should stay when the screen goes back then its the LD board...Good luck...
Search results for kdl70w850b
Posted on Mar 04, 2018
  • 4 more comments
  • vincent colan
    vincent colan Mar 04, 2018
    thank you Larry, very helpful i saw a video of a guy changing out light strips on a sony different model than mine , do you know if these are light strips and do you have a part # for my model, also what pin on the pmw would i measure the voltage at
  • Larry Mar 05, 2018
    Your welcome Vincent!...I don't have the manual out for your set but there will be a legend as to what pin is what on the power board. Almost all Sony TVs use the same voltage lamp but the connectors can vary along with length, you would need to take the part number off the strip as they can vary in the same model TV
  • vincent colan
    vincent colan Mar 05, 2018
    your the best thank you again, this is my son's tv he saved for awhile and bought it now 2yrs later hes not a happy trooper so im trying to help, so when i get a chance to get into this project and if its the light strip/bar who carries this part seems sony is hard to get certain parts or do you know any body in the long island ny area the fixes this
    Try shopjimmy.com and search by part number on the strip, sometimes they can be found on ebay as well but you take a chance on getting a bad strip from there, Ive had it happen several times
  • vincent colan
    shopjimmy has none in stock at the moment when they do they said they will notify me at that time ill take it apart and see the part # before ordering , they said the same thing about getting the part # since parts vary on the same model # thank you
    A lot of times Ive had to wait a couple weeks for parts from shopjimmy but I think its worth the wait verses go somewhere else.
Mark Miller
    New Friend:
  • 21 Answers
Sounds like blown capacitors look on youtube loads of videos how to fix problem just type in how to fix make model of your tv then stuck in stand by mode hope it hopes you out
Testimonial: "thanks for reply, but its not stuck in standby mode, i found nothing on capacitors repair for my model do you hacve a you tube link thanks"
  • 2 more comments
  • Mark Miller Mar 04, 2018
    hi just type in how to fix tv stuck in stand by should find loads all the same just different boards
  • vincent colan
    that seems just for a reset i've done that many times
    How To Repair 40" Sony LCD TV With 4 Blinks - YouTube
    Sony Bravia TV kdl- red blinking led light error codes & solutions ...
5 Related Answers
Bill Heronemus
  • 308 Answers
SOURCE: my sony tv will not stay on
If you replace the lamp and need to reset the Lamp Timer Reset procedure is: With The Set In Standby Press Display, 5, Vol Up, Power on the remote control Press Jump 3. Or, To Display The Lamp Time Press 2 Nine Times. To Reset Press 3, Mute, Enter. One of these should work on your model. Make sure you replace the bulb first. There is a possibility that the ballast could be damaged by a defective bulb as well.
Posted on Jan 18, 2007
Anonymous
SOURCE: Sony KF-WE50
my front panel sound is not working.......?
how i can do this.?
Posted on Jan 05, 2008
mortworker
SOURCE: Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
My Sony KV36HS500 Trinitron is doing the same thing. Last night the next street over was hit by lightning. The "7" blink pattern was happening, so like the manual stated, unplug it for 4 hours. Which I did. The t.v. is back up and running fine. It's a nice t.v., better than the plasma I paid over a grand for, that's already shot. It's a good t.v. and good that Sony put in the stand by protection to prevent the t.v. from dying an unnecessary young death. Patience, don't rush it, unplug the t.v. and leave it sit. Also, don't use a power strip, that was my mistake, and unplug your t.v. if storms are in the area, I was too lazy to and now I had to deal with this, in 8 years, only twice did this happen. I'd buy another one tomorrow if they still made them.
Posted on Jun 15, 2008
Pamcredible
  • 8 Answers
SOURCE: Green flashes then tv turns off
OMG! My TV has been sitting in a closet for the last three years because I couldn't afford to have it fixed.  I have googled now and then trying to find a cure for its green affliction but never found the right advice until tonight. I can't thank J19666566666 enough!!  I just followed the instructions and presto!  Working TV again! And just in time for the Oscars (which is like the Super Bowl for me).
The editor in me tweaked the instructions a little...
Its is real easy to fix. There are 2 screws holding the front speaker cover on near the bottom corners (there are plastic plugs covering the screws that need to come out first). Unscrew and remove the speaker cover (pull it out from the bottom a little then sort of down and out to get it loose but be careful because there are wires attached). Next remove the 4 screws holding the particle board panel in place. There will be a cluster of 6 adjustment nobs with a drop of white paint on each one (2 rows of 3 - do not touch the top row). The green is controlled by the bottom middle screw, Using a screwdriver turn it counter clockwise (to the left) ever so slightly (1-3mm) and there you have your TV back. Use the bottom right screw to adjust the red and bottom left screw for blue.
Thanks again so much!
Posted on Feb 23, 2009
Anonymous
SOURCE: 55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Posted on Sep 28, 2009
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
Mitsubishi 65" LCD (1080P, DLP) keeps shutting down until it "warms up". After shutting down the power led flashes yellow for a minute or so, at which time I power it up again. This cycle repeats 1 to 4...
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV may require service.
Jul 27, 2010 | Mitsubishi LT-40133 40 in. LCD HDTV
I have a Panasonic PT-50DL54 50" rear projection tv. My tv screen won't come on but the fans will. The power led light flashes green like normal but than starts to flash fast for about a minute than the...
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
Jun 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
TV PICTURE GOES OUT AND THEN SHUTS OFF
sounds like dodgy buffer board or video pcb
Sep 25, 2009 | Televison & Video
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
TP50G60 bad scrambled picture - shuts off after 1 minute
This does not sound to me like a convergence roblem. It could be a shorted picture tube. That would put the set in a shutdown condition. Normally in Toshibas , the picture remains on with a convergence problem. Here is something you can try, but you must be very careful. Remove one crt board at a time from all three tubes. if the set stays on after one of the crt board are removed , then that is the shorted picture tube.I cannot caution you on how care full you have to be trying this procedure. Scrivitron
Jun 29, 2007 | Toshiba TP50G60 50" Rear Projection...
The flashibg red light
John, I do not know of a code, but it is a good idea in the design to have several goes at starting a circuit, before completely shutting it down. Oscillators are supposed to self start due to noise generated. Some electronic circuits require a reset pulse to be generated before the start up is allowed. The reset circuit may not be generated if the set is turned on again too soon, so it will stay in standby. This may normally be a few minutes to 30 minutes so it seems something in your set is faulty and could get worse. Try a test run with the back off and clean it out of dust with a long brush to keep it cooler. Make sure little fingers cannot get near it. Look to see if anything is obviously overheating.
Oct 21, 2006 | Thomson 24WK25U 24" TV
Televison & Video Logo
3,562 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
