Question about Garmin nuvi GPS
Garmin nuvi 2225 will not acquire satellites in Europe. Worked fine in North America. I loaded maps for Europe but no action.
Posted by Chase Faust on
Michael Grimes
    Scholar:
  • Garmin Expert
  • 195 Answers
If the garmin can reach satellites in North America, it will reach satellites anywhere in the world as long as it has a clear line of site to the satellites. Depending where you are, the satellites can be higher or lower in the sky. This means that the garmin in your vehicle may not be able to see the satellites how you have it positioned in your vehicle. Try finding the satellites outside of your vehicle while in Europe. If you can, then the problem is positioning in your vehicle. The satellites are all the same kind no matter where you are.
Posted on Nov 13, 2019
5 Related Answers
Anonymous
  • 113 Answers
SOURCE: Nuvi 660 MapSource
Henry,
You cannot replace American maps with European maps.  Garmin does this in order to protect the European retailers.  The European SD card eliminates the need to load the maps into the 660, however, if you need to use the card slot to store extra data such as MP3s then you might be better off buying the 670.
Posted on Oct 29, 2007
Anonymous
SOURCE: Nuvi 205w won't read upgraded map
You HAVE to go through software support as this is an issue with the map. They told me it is because the map KEY is wrong, it is only for the united states, but the map is ALL of north america. The wait time is incredibly long, I have been waiting for over an hour, such bad service
Posted on Apr 17, 2009
Anonymous
  • 3 Answers
SOURCE: Call 1-8O5-225-669O GPS/GARMIN Update-Install-Download-Fix We are 24 Hour Available Call Now For Help
I just got off the phone with tech support. They have a very complicated fix that involves remote accessing into your computer and editing files, etc. They said it would take over an hour and a half, I declined. The problem apparently is that the nuvi 200/205 can't support canada, but the maps contain canada = problem. and btw, i downloaded "City Navigator Lower 49 States+PR NT 2010.10, Deluxe, Apr 09" and got the same problem. this filename ends in a "B", apparently that's the "fixed one" but acc tech support it's only fixed in the sense that they can waste over an hr w' u fixing it, whereas the older files are unfixable.
I'm just gonna wait til they really fix it and upload those files.
Hope that helps.
gemmy23
Joy Shannon
  • 346 Answers
SOURCE: Have a Garmin nuvi 200 with North America maps.
It will depend on how much memory you have in your Garmin. If you have maps that you want to keep then I would download those first and then add in the Ireland maps. Or wait until you leave to add in Ireland. I believe the Garmin will tell you if there isn't enough room to add in Ireland.
Posted on Aug 17, 2009
Testimonial: "Thanks again Gemmy23"
Anonymous
  • 1514 Answers
SOURCE: my nuvi 3760T does not
If you have the map downloaded from the garmin website to your computer you could remove it and replace it later. However a better option might be to download the map of Europe to your computer and install it to a micro SD card. A 4 Gb card would hold the map of Europe and you don't risk losing your North America map. You can get details of how to set up the map on your micro SD card at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
While this link is mainly about how to update your maps it has a section on setting up maps on an SD/Micro SD card also.
Posted on Mar 26, 2011
My garmin nuvi 2225 will not acquire satellites since I brought it to Europe. I loadd maps for the area but it can not find its position.
Garmin nuvi 1450 problems
You need to download a Garmin tool called "Garmin Express" to load the map software off the Garmin site.
May 19, 2017 • GPS
I just bought a Europe map from garmin for my nuvi 1300 and when I try to download it I get the message "insufficient Space". I have a North America map on my Garmin that I am not using at the...
Yes you do have to remove the North America map, I was just checking on the specs and they do not list that it supports a memory card so unfortunately due to the lack of available space on the solid state drive that comes built into this unit you will have to do the map switchover.
My nuvi 3760T does not have enough space to load europe map. Can I remove preloaded north america map and reload at a later date without losing it?
Mar 26, 2011 • Garmin GPS
2answers
My Garmin 765t stopped navigating
There should be a small reset switch on the back of most garmin gps units. with the unit on, depress the reset switch with a pen tip or small object until the unit shuts off and restarts. It may take a little longer to pick up the satellite but it will reque the unit and unlock the navigation screen.
I want t travel accross europe and do not have full addresses to enter into my garmin nuvi 250 please could you tell me how to do this Lynn
The nuvi 270 is the model that comes with pre-loaded maps of europe. The nuvi 250 only has North America. You can find the right maps on Garmin at: https://buy.garmin.com/shop/buymaps.do
You can purchase all of europe or select areas which are $50 dollars cheaper.
Jan 20, 2009 • GPS
2answers
Going to Mexico and my garmin will not display it.
There are a variety of Garmin® GPS devices that come preloaded with mapping not just for the United States but also for Europe and Mexico. Any nuvi® that has 70 in the model number will have preloaded mapping for North America and Europe.
Example: nuvi 270, nuvi 370, nuvi 670, nuvi 770
Also, some specialty models will have preloaded mapping for North America and Mexico. These units include the nuvi 200 Mexico (p/n 010-00621-2A) and the Nuvi 260W Mexico (p/n 010-00656-37).
To obtain Mexico maps, go to this link:
http://www8.garmin.com/cartography/mapSource/citynavntmexico.jsp#price
Oct 11, 2008 • Garmin GPS
Nuvi 660 MapSource
Henry,
GPS Logo
Top Garmin GPS Experts
Tom Chichester
Steve P
Steve P
Aron
Are you a Garmin GPS Expert? Answer questions, earn points and help others
