GPS Logo
C
Chase Faust Posted on Mar 03, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My garmin nuvi 2225 will not acquire satellites since I brought it to Europe. I loadd maps for the area but it can not find its position.
Michael Grimes
Level 2:
Scholar:
  • Garmin Expert 195 Answers
  • Posted on Nov 13, 2019
Michael Grimes
Garmin Expert
Level 2:
Scholar:
Answers
195
Questions
0
Helped
38684
Points
395
If the garmin can reach satellites in North America, it will reach satellites anywhere in the world as long as it has a clear line of site to the satellites. Depending where you are, the satellites can be higher or lower in the sky. This means that the garmin in your vehicle may not be able to see the satellites how you have it positioned in your vehicle. Try finding the satellites outside of your vehicle while in Europe. If you can, then the problem is positioning in your vehicle. The satellites are all the same kind no matter where you are.
5 Related Answers
Anonymous
  • 35 Answers
  • Posted on Jan 21, 2008
SOURCE: Garmin Nuvi takes a long time to Acquire satellite
No. 98% of the time it took 45-56 seonds for your NUVI 660. Thats the compagny set up time acquisition and it did very well.
Be sur you had your flip antenna parallel to earth surface.
660 has THE BEST SIRF Chipset for acquiring satellite.
I had 2 NUVI 660 since 2 years. It work much better than those new 7xx series who it really took 2-3 minutes to acquire satellite.
Be sure you update your version to the last one.
----> https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=134&pID=400
Best regards
Anonymous
  • 40 Answers
  • Posted on Jan 02, 2009
SOURCE: won't acquire satellite
Try this and see if it fixes your problem...first disable bluetooth then follow these steps....
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the problem.
Anonymous
  • 3 Answers
  • Posted on Mar 03, 2009
SOURCE: Garmin Nuvi 360 - Acquiring Satellites
I had a problem with my Nuvi 360 that it couldn't find the satellites. I couldn't solve the problem with resets or updated software, but a new, external antenna that plugs into the side of the folding antenna seems to have solved the problem. Available from Wireless Finest through Amazon.com - like $11.50. Great solution - can't beat the price.
Anonymous
  • Posted on Aug 13, 2009
SOURCE: Update for Garmin nuvi 200
I just got a Garmin Nuvi 660 and cannot figure out how to charge the unit. Help!!!!
Anonymous
  • Posted on Feb 06, 2010
SOURCE: How do I get Malta Maps for Garmin Nuvi 200w
there are still no released maps for Malta. You have to buy them from a local company
Garmin nuvi 2225 will not acquire satellites in Europe. Worked fine in North America. I loaded maps for Europe but no action.
My garmin nuvi 1450 repeatedly says "acquiring satellites". How do I fix this?
Take it into an open area such as a parking lot or field, it will soon acquire the satellites and they will stay acquire unless you go into a parking garage.
I brought my Garmin 1260 that I used to use in LA to Florence Italy. After putting the small card for Europe to the little slot, I have problem. I can find the location no problem but satellite is not...
I'm afraid the 1260 that is made for USA will not work in Europe. The only satnavs that work in both Europe and USA are those that have both maps of Europe and USA pre-installed.
2helpful
My garmin 205 seems to have lost its fix. Its position is out by about 100m, tracking established roads but to one side or other then loses roads altogether then gets totally lost. Is a map update...
Whenever these devices start acting up, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device. There have been numerous fixes to the firmware to allow the Garmin 205 or acquire satellite signal faster, and to be more accurate with your location.
I hope that helps.
3answers
Can the garmin 72 gps bought in usa be used in europe and are
GPSs can be used anywhere in the world with the correct maps for you particular area installed. They use the same satellites.
Oct 30, 2009 • Garmin GPS
Picking up satellite in Paris
New maps should come with an unlock code did you get one and did you enter it?
Also make sure your battery is fully charged
Thanks for using FIXYA
I want t travel accross europe and do not have full addresses to enter into my garmin nuvi 250 please could you tell me how to do this Lynn
The nuvi 270 is the model that comes with pre-loaded maps of europe. The nuvi 250 only has North America. You can find the right maps on Garmin at: https://buy.garmin.com/shop/buymaps.do
You can purchase all of europe or select areas which are $50 dollars cheaper.
Jan 20, 2009 • GPS
2answers
Garmin nuvi
If a GPS gets a factory reset, powered off for months, or powered up again in a different country, it will eventually scan the sky for any satellite it can find, and then download a new almanac and ephemeris - which can take up to 12 minutes after it finds the first satellite. This is best done stationary, to minimize the doppler effect until a fix is acquired.
3answers
Trouble acquiring satellites
Garmin nuvi
Best regards
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
