If the lights all go out, I can hit the power button again and the unit will power up and function correctly. Today though, the lights won't stop flashing, and I've unplugged the unit multiple times.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty./
SOURCE: no power,red power lights keeps flashing.
Just my coment THis tv has a complex system that include a digital signal porcessing in a high levle technology to show a good performance, i myself work on the development of that model, we was thinking we are best, for improve that many eng. dedicates almost all life to have that technology in our rooms, I offer my apologize for that but many eng dedicates all year 18 hours a day to fix that, thanks
SOURCE: LC 32D43U power and OPC green light flashing set does not come on
get the usb (flash drive) and go to sharpusa.com customer support / product downloads / software download find your model# then select firmware (last 30 days) download files, save it and transfer files to usb flash drive. Unplugg the tv and put the usb on the back the tv, plugged back in and turn it on. Should work, for sure.
SOURCE: Toshiba Satellite C655-S5082. Won't power
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Lid switch was flashing on/off now won't even light washer fill and pumps out but won't wash or spin HELP
