Cameras Logo
Question about Olympus Cameras
My camera turns on except for the screen and the screen sometimes flashes on but then shuts back off. How can i fix this?
I have an olympus fe 4020 14 mp camera
Posted by celeste cortes on
5 Related Answers
Anonymous
  • 641 Answers
SOURCE: problem in Olympus FE-170 Digital Camera
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Posted on Aug 13, 2007
Anonymous
  • 20 Answers
SOURCE: FE 170 OLYMPUS digital camera
The lens need to be replaced or repaired. It is not fully extending. It may be that one or more of the plastic gears or plastic rods that hold the gears in place, are broken. I repaired two plastic rods in my lens, by drilling holes for new plastic rods,(I cut plastic rods from a plastic toilet bowl chain!!! It fit inside the gears perfectly), and super glue the rods in place. Replaced gears, put camera back together and BAM in worked! Nothing like a perfectly working refurbished rig job. Camera takes great pictures to this day.
Posted on May 18, 2008
Anonymous
  • 70 Answers
SOURCE: fe-340 wont turn on
If the lens is stuck out, that either means impact or it got squished and messed up the lens mechanism. You can have that repaired.
Posted on Apr 20, 2009
Anonymous
  • 2761 Answers
SOURCE: my camera keeps turning off when i try to take a picture even whe
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Posted on Nov 29, 2009
Anonymous
  • 11967 Answers
SOURCE: Camera will not turn on
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 31, 2009
I have an olympus FE-290, and my sister borrowed it for a trip but when she brought it back the camera was messed up. it turns on but the screen is black except for information about the number of pictures...
I would try looking in the settings to see if the view finder option is enabled or disabled. I would also ask your sister if she change any of the settings.
The flash does not work even if the flash setting is SET to FILL ( the flash will work every time the camera is in used) I already tried to reset the settings to default but still the flash wont...
Does the camera indicate that the flash is turned on? In most olympus cameras I have seen there is a lightning blot at the lower left corner of the screen. Verify that it is indeed there and let me know.
2answers
Olympus FE-190. The flash won't work. Doesn't fire at all. How do I fix?
http://www.olympusamerica.com/cpg_section/cpg_support_faqs.asp?id=1262
The above is the faq page of the Olympus FE-190.
http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp
I believe your camera is in need of service after not finding the solution in the FAQs of the camera on Olympus.com.
Try the above link to schedule service.
Fe-340 wont turn on
1helpful
MY OLYMPUS FE-115- THE FLASH DOESN'T GO OFF
You can try to reset the camera back to factory settings to see if the flash will start working again. To reset: Have the camera in shooting mode - press the down arrow - camera will indicate reset or cancel - highlight reset and press ok - the camera will be back in factory settings - see if flash fires - if it does then fine - if you see a red flash charging icon blinking on the screen this is a repair issue and the camera needs to be sent to Olympus for service.
Olympus FE-140 ok except that flash does not work
Make sure you try and reset the camera to the factory default settings. There may be a setting that you are using that has disabled the flash functionality. To reset the camera - have the camera in shooting mode - press the menu button - left arrow to reset and press ok - you will see reset yes or no - highlight yes and press ok - camera will be back in factory settings - see if flash is able to work now.
2answers
Olympus FE-210
Hey dramaqueen79,
It sounds like you have internal damage to the camera. I would have it looked at be an authorized service center. If you are fine with the performance of the camera and all you want to do is be able to upload your images you could purchase a card reader(for an xd memory card) that connects to a usb port, and upload your images directly to your computer with the card reader.
Sincerely,
Allan
Go Ahead. Use Us.
Camera problem =/
In addition to the one year World Wide Warranty,
issued by Olympus Corporation in Japan, the European warranty, issued by Olympus Imaging Europa GmbH, is
valid for two years from the date of purchase, if purchased after 1st April 2004
Broken camera
Lens wont retract
Lens motor is shot - check out Olympus web site for repair options-not cheap
Top Olympus Cameras Experts
Steven Wander
Steven Wander
David Shaub
Steve
Are you an Olympus Camera Expert? Answer questions, earn points and help others
