SOURCE: HP Pavilion dv5000 PC Notebook
i have hp dv5000 as well. and i had the same problem.
what helped me is that:
you go to start - control panel - administrative tools -
then take: device manager.
in the device manager window you click on the plus near:
IDE ATA/ATAPI controllers
right click on: primery IDE channel
and select uinstall.
at that moment you will probably feel that the computer is back to its speed. restart anyway.
it will tell you new hardwear found, click: ok to everything it will install the primery IDE chenell again.
well that worked for me...
SOURCE: Sony Vaio speakers are echoing, cutting out, causing delay.
Sony's web site has very thorough driver support. Log onto sony.com and download & install the latest audio driver for your system.
SOURCE: Sound problem: scratchy and distorted
That sound card isn't really being claimed by anyone anymore, both Intel and Realtek have washed their hands of it. You can do a few things. If it's a dell laptop, theres a Motherboard Update that fixes these problems (which must be installed first), there are also alternative drivers that come from the Linux world that you could try (no offense but your sound card isn't that wonderful to begin with, so I would think just sound without distortion would be good sound. It also just might be time to update your drivers and have them with me strangely enough. Let me know what you want to do.
SOURCE: Leapster L-Max with No Sound
We had the same problem and I found the speaker was broken. Radio Shack part # 273-0092 is almost a direct replacement. Under $4 and works like new now.
SOURCE: philips HTS8100 owner. Have
Same problem with my HTS8100. Little-to-no sound. Sometimes sound comes on very intermittently. I downloaded the software patch from the Philips website and installed it. This fixed the sound problem for about a week, then the problem came back. I'm not sure what else to do.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope this helps you
if his does not fix the problem
