Sewing Machines Logo
L
Lee Ann Brandt Posted on Mar 02, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Juki HZL 70HW sews forward in tiny stitches, sews backwards in long stitches. Decorative stitches sew backwards
R.A. Ellis
Level 3:
  • Juki Master 12,731 Answers
  • Posted on Mar 02, 2018
R.A. Ellis
Juki Master
Level 3:
Answers
12731
Questions
Helped
2613430
Points
59176
Sounds like it needs to be serviced.
4 Related Answers
RickE1
Rick
  • 202 Answers
  • Posted on Jan 11, 2009
SOURCE: backward stitching
Knowing which kind of machine you have helps alot. Just guessing but maybe the reverse mechanism is stuck and needs some oil in it to free it up. Or the buttonhole mechanism is stuck in reverse part of it.
Probably you should have it looked at.
Anonymous
  • 188 Answers
  • Posted on Mar 26, 2009
SOURCE: needle stuck in right position, will only sew tiny,tiny stitches
oil it. down the shaft if you can get to it. and where ever there is a hole it always helps.
MissFixIt828
  • 70 Answers
  • Posted on Feb 25, 2010
SOURCE: Pfaff 1222's 3 stretch stitches sew wrong and backwards only.
It sounds like the feed mechanism needs oil.
Rick Beament
  • 166 Answers
  • Posted on Aug 28, 2012
SOURCE: Why does my machine now only stitches backward, and no decorative stitches
You dont state what model of machine this is, however I have come across this problem mainly on Elna computerized machines and it has been exclusively due to failure of the driver chips on the processor board that control the stitch length stepper motor. You can confirm this by checking whether you can vary the stitch length as well as just the forward/reverse. Same applies to Bernina models, but I dont know about others. Either way, you need to have it checked by your tech.
I need a juki hzd 688 manual
HZL or HZD?
HZL-L series - JUKI
https://www.juki.co.jp > HZL-L Series_EN_inst
PDF Keep this manual accessible so that you may refer to it at anytime while operating the machine. INSTRUCTION MANUAL. COMPUTER SEWING MACHINE.
2answers
Why is it seizing up and clocking after doing basic sewing?
Juki HZL F300 Exceed Sewing Machine at Ken's Sewing ...
www.kenssewingcenter.com/juki-hzl-f300-exceed-sewing-machine-p-30...
The Juki HZL F300 Exceed Sewing Machine is a classroom model and will exceed ...High speed sewing up to 900 spm, stitches per minute; Power at low speed ...
Juki HZL F300 Exceed 106 Stitch Computer Sewing and ...
www.allbrands.com/products/22395
$749.00 - ‎In stock
Juki HZL F300 Exceed 106 Stitch Computer Sewing and Quilting Machine +$50 Knee Lift Lever + $50 ... High speed sewing up to 900 spm, stitches per minute
Juki Exceed HZL F300 Home Deco Computerized Sewing ...
1helpful
Fabric won't move doing straight stitch.
Be sure that the stitch length is set to a higher number. The closer to zero it is set, the closer the stitches will be until zero when it will actually be sewing in one place.
Requesting support: juki HZL F6000 suddenly stopped sewing straight stitching in a straight line. Also stopped automatic treading.
the machine may need to be serviced, the needle bar may need adjusting, also could be something wrong with the motherboard
1helpful
Juki HZL-E61: cannot get tension right on straight stitch
Loops on the bottom of the fabric direct the problem to the top thread. Rethread again and make sure the thread goes through the tension discs. Lift the foot, because this is what opens the discs. When sewing and the foot is down, the discs should be closed and thus giving the upper thread the tension it needs.
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
