Pioneer DEH-P2500 CD Player Logo
Posted on Nov 24, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I NEED TO KNOW HOW SET THE CLOCK ON A DEH-1500 PIONEER
I NEED TO KNOW HOW TO SET THE CLOCK ON A DEH-1500 PIONEER
        THANKS
I NEED TO KOW HOW TO SET THE CLOCK ON A DEH-2500 PIONEER
  • Elimo Nov 24, 2007
    I tried that but it never shows up CLOCK in the middle, it only shows two functions
Anonymous
Level 3:
  • Master 709 Answers
  • Posted on Nov 24, 2007
Anonymous
Master
Level 3:
Answers
709
Questions
Helped
609610
Points
1733
Hi Elimo
Two pics as the manual had the paragraph separated. This is for DEH 2500 only. Let me know if you want the 1500 as well.
  • Anonymous Nov 24, 2007
    Try this one,
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 02, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1900
Points
Please how can I set the clock in my Pioneer WMA.MP3 deh 1900mp. thanks
How to set clock on a pioneer car radio mosfet 50wx4
Mosfet 50wx4 indicates a feature of the Pioneer car radio. It isn't a model number. One Pioneer car radio/CD player with this feature is the DEH-1500. On this model, you need to turn off the unit to set the clock. Press and hold the Source button (to the left of the preset tuning buttons) until the device turns off. Press Audio (upper right corner) repeatedly until the clock appears in the display. Use the arrow keys (Skip/Back or Left/Right) on the right hand side of the radio to select a segment of the time to adjust. Use the Up/Down arrows to set the current time. Repeat choosing the time segment and adjusting the time until both the hour and minutes are correct. Press Band or press and hold the Audio button to exit the clock setting mode.
ManualsLib has the manual for the Pioneer DEH-1500 here: https://www.manualslib.com/products/Pioneer-Deh-1500-Car-Cd-Player-Mosfet-50wx4-Super-Tuner-3-Am-Fm-Radio-3432555.html . See page 16 for the clock setting procedure: https://www.manualslib.com/manual/129844/Pioneer-Deh-1500.html?page=16#manual . See page 6 for the picture of the front-panel buttons for the DEH-1500.
I hope this helps. Please add a comment with the model of the car radio if the above procedure doesn't work for your unit.
I need to know how to set the clock on my pioneer car cd player model DEH-P4000UB.
Try this with your key in the on position and the radio off. Hit the clock button. When the clock appears, hold the clock and audio button at the same time. Thats the way my pioneer does it.
Need to know how to set clock
send proof of ownership for help>
4helpful
Fix my clock pioneer deh-1500
For most Pioneer single CD players, you can set the clock using the following steps:
1. Press and hold the SOURCE button until the unit turns off.
2. Press and hold the FUNCTION button, until display pops up, then release. (If you do not have a FUNCTION button, then push the AUDIO button)
3. Press the FUNCTION button again until the clock shows on the display.
4. Press the UP and DOWN buttons to adjust the hours.
5. Press the LEFT or RIGHT arrows to move to the minutes.
6. Press the UP and DOWN to adjust minutes.
7. When complete, press the SOURCE button to exit.
Hope this helps!!!
Pioneer
You can find a manual for your deck at: http://akamaipix.crutchfield.com/Manuals/130/130DEHP390.PDF
Page 34 walks you thru how to set your clock. You can save this manual for future reference. Thanks
1helpful
Pioneer DEH 1500
Here's a link to the manual at Pioneer's web site.
Here's how you set the time (from page 16 in the manual):
1: press SOURCE and hold until the unit turns off.
2: Press AUDIO repeatedly until the clock appears in the display
3: Press (left arrow) or (right arrow) to select the segment of the clock display you wish to set (hours, minutes)
4: Press (up arrow) or (down arrow) to set the clock.
- To cancel clock settings, press BAND
- to save clock settings press AUDIO until the display stops blinking
Pioneer deh-1500 same problem i see posted from someone else`
Press SOURCE, and hold until the unit turns off.
Press AUDIO repeatedly until clock appears in the display.
Press < or > to select the segment of the clock display you wish to set.
Pressing < or > will select one segment of the clock display
Hour - minute.
As you select segments of the clock display, the segment selected will blink.
Press v or ^ to set the clock.
Pressing ^ will increase the selected hour or minute. Pressing v will decrease the selected hour or minute.
To cancel clock settings, press BAND.
You can also cancel clock settings by holding down AUDIO until the unit turns off.
2helpful
Changing the time
Here's a link to the manual Pioneer's web site.
7helpful
4answers
Found a posting on another site from 2005, and it worked!
Turn on the radio. Press and hold the "Source" button until the radio goes off. Press and hold the "Audio" button until the numbers flash. Use cursor/arrow buttons to adjust the time. Press and hold the "Audio" button to exit.
1helpful
2answers
Time set
How to change the time on a Pioneer DEH 1500 car stereo:
With the radio off, select the 'clock' (upper left button) to display the time.
Press and hold the 'audio' (upper right button) until the time display blinks.
Use the 'select' buttons to select the hour or minutes and adjust time (right button selects minute digits, left button selects hour digit, up button increases the time, bottom button decreases time). Comment by dognut, posted on Dec 25, 2007 Just a further comment posted by dognut:
After setting the desired time, 'press any
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
ZJ Limited
ZJ Limited
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
