Tablets & eReaders Logo
s
steve Posted on Mar 01, 2018
Again, how did i recently find accidentally my passwords list in my polaroid kindle?
How cancel kindle book order accidentally ordered on wrong kindle account
It's instant, and as far as I know they can't tell if you sent it to your Kindle or not, you'll either have to buy it again or transfer the file once you download it.
1helpful
Why can't I connect to internet or do anything with it?
if reset is done you usually have to set it all up again. including wi-fi ,passwords etc
How to tune in kindle to wi fi?
From the Home screen, press the Menu button.
Select Settings, and then select view next to Wi-Fi Settings.
In the list of detected networks, choose a network to connect to it.
If your Wi-Fi network and router support WPS (Wi-Fi Protected Setup), your Kindle will detect it.
If you don't see your network in the list, you need to add the network manually.
If the network is protected by a password or WPS (Wi-Fi Protected Setup), enter the password and then select Submit.If you don't know the Wi-Fi network password, contact the person who set up the Wi-Fi network.After you connect to a Wi-Fi network, your Kindle automatically connects to it again whenever that network is in range. If more than one network is in range, your Kindle automatically connects to the last network used.
Authentication problem when trying to connect Kindle to internet
go into settings and select wifi a list will pop up select and connect
1helpful
2answers
Kindle say authentication problem when trying to connect to wifi
Im sure you would have typed wrong password. please make sure you have correct password typed.
-regards
Accidentally removed a new book I just ordered
Look for Archives; It may have been moved there. If you checked the list and can't find it, contact Kindle and they will resend it.
1helpful
Accidentally deleted a b ook I just bought
If you deleted it from the Kindle it will still be on your Amazon account in your archive/cloud.
From your HOME page click Cloud/Archive, possibly sort by most recent, touch the book title and download it again to your kindle.
If you deleted it using MANAGE MY ACCOUNT then you will need to contact Amazon Customer Services using the HELP button. They may help you if it's rare event.
2answers
Forgot passcode
Kindle Fire:
If you can't remember your lock screen password or PIN, you will need to reset your Kindle Fire.
Important: Resetting your Kindle Fire will remove your personal information (including your lock screen password or PIN), Amazon account information, and downloaded content and apps. Any content you purchased from Amazon is automatically saved to the Cloud. You can download that content when you register your Kindle Fire to your account again.
  1. From the lock screen, slide the Unlock Bar from right to left.
  2. Enter characters into the prompt ten times. You will receive several warning messages. Dismiss the warning messages, and continue entering characters into the prompt.
After you've entered the incorrect password or PIN ten times, your Kindle Fire will reset.
Kindle Paperwhite:
If you can't remember the passcode for your Kindle you'll need to reset your device.
  1. Transfer from a Computer to Your Kindle Paperwhite.
  2. You can't reset your Kindle Paperwhite if Parental Controls are set. If you forget your password, reset your Kindle by entering "111222777" as the Parental Controls password.
    Important: Resetting your Kindle will remove all content downloaded to it. Any content that is already saved to Your Kindle Library in the Cloud will remain in the Cloud. You can download that content again if you register your Kindle to your account again.
    1. From Home, tap the Menu icon, and then tap Settings.
    2. Tap the Menu icon again, and then tap Reset Device. Your device will power off and power back on.
    To use your Kindle again, you'll need to connect wirelessly and register your Kindle.
2answers
I recently bought a kindle and have forgotten password that goes with my ssid number can you help
HI
IN CASE YOU HAVE FORGOT YOUR PASSWORD JUST SEARCH FOR THE RESET BUTTON IN THE KINDLE DEVICE
PRESS THE RESET AND NOW YOUR SSID IS ALL NEW
THANK YOU
Top Polaroid Tablets & eReaders Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
nexrad_chris
Are you a Polaroid Tablet and eReader Expert? Answer questions, earn points and help others
