Question about JAKKS Pacific Toys
Needs manual for Jakks Pacific video watch model 2361RL01
Posted by Sandra Borelli on
Terry
  • JAKKS Pacific Master
  • 11,377 Answers
[email protected]
(877) 875-2557
Posted on Mar 01, 2018
2 Related Answers
Anonymous
  • 10 Answers
SOURCE: Have a Jakks Pacific WWE Tables Ladders and Chairs
Ok so what you need to do, and yes I am the real Jeff Hardy, but anyway you need to take the ring ropes and you will see the little attachments on the ringsides, hook the ropes up to that.
Posted on Feb 04, 2010
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: Need user manual for Pacific Fitness model Delmar
Call Inflight fitness @ 1-714-821-4177 the engineer that designed the pacfit units are the owners of this company they may be able help you.
Posted on May 14, 2010
What chargers work with Spynet watch besides on what it came with?
If your watch has micro usb socket that regular micro USB cable and phone charger will work
Mar 05, 2018 | Jakks Pacific Spy Kit
What other chargers for Spynet watch that work?
All you need is a mini-USB to USB cable. Then use your laptop or any open USB port to charge.
Feb 05, 2018 | Jakks Pacific Spy Kit
My spynet video watch is dead and evertime i pug it in it says battery charged.
get ur USB and plug it up to the computer and and then plug it up to ur watch, and the computer has to be on, so play on the computer for a while and then it should be charged if not then u should return it or buy a new one.
Jul 14, 2011 | Jakks Pacific Spy Kit
How do we charge the Spynet watch from Jakks pacific?
connect the usb plug from the watch to a PC or laptop while the pc or laptop is on.
Jan 07, 2011 | Jakks Pacific Spy Kit
I bought our son a Spynet Video watch for Christmas and we charged it but when we removed it from the charger, it turned off and wouldn't turn on. I then thought maybe we needed to download some kind of...
A bit late to the party, but two things come to mind. If the watch is new old stock with a few years on it, more than likely the battery is bad, it won't charge any more. Also, the power supply may be bad, I use 5 volt one amp charger, also, the manual says to charge it with the screen on, I tried that, and the battery will never be fully charged because the screen being on drains the battery faster than the charger can charge it.If the watch is working but the battery is low, connect the charge cable to the watch, then to the charger, otherwise the charger will pull the battery down too. So, let the screen go blank, then charge it, I have tried this method multiple times, and every time, assuming the battery is good, it fully charges in few hours. If you are adventurous, you can upgrade the battery to 450mah, it's a little bigger than the one it comes with, but lasts a lot longer, only a small amount of modification to the plastic strips made into the watch back need to be done, simply remove the strip closest to the electronics and it will fit just fine.
Nov 21, 2017 | Jakks Pacific Spy Kit
Jakks spytech watch only will work when connected to USB port of computer. If disconnected it goes blank and will not operate. When connected toi USB port the following message is the only thing...
Same problem. But I am able to set the location, time and date while usb connected. As soon as I pull it out, total failure. Even tried the RESET button on back, but nothing works.
Anybody... anybody?
Dec 27, 2010 | Jakks Pacific Spy Kit
My son got a Spynet Video Watch for Christmas. He has been charging it for over 5 hours and it still doesn't show a full charge. It only shows half a charge and when he takes it off and tries to use it...
Hello, Pdschanz -
Since the watch was a Christmas gift, it is probably still under warranty.
I hope you found and downloaded the instructions for the watch, saved them in a Documents file with a file name you can find again easily, printed the instructions, and read them thoroughly all the way.
If you have not yet contacted Customer Service for the watch, I suggest you do that after reading through the instructions and the FAQs near the end of the instructions.
This is the telephone number for Customer Service for Jakks Pacific Inc., manufacturer of the watch:
877-875-2557
Malibu, California
Call weekdays during normal office hours, Pacific Time zone.
This is the email address for Jakks Pacific Customer Service:
[email protected]
Source of information:
Instructions for Spynet Video Watch with Night Vision
http://www.spynethq.com/core/pdfs/instructions/Video_Watch_with_Night_Vision.pdf
Best wishes.
Jan 21, 2018 | Jakks Pacific Spy Kit
New Spynet Video Watch will not charge. Will only turn on with charger attached.
The external battery pack supplied in the box with the watch works in "Try Me Mode". There is a reset button on the back of the watch. Reset the unit and the USB port will work. I have two units that had exactly the same problem. Both are charging now!
Dec 26, 2010 | Jakks Pacific Spy Kit
Already lost the instruction manual for the Spy Net Video Watch....must have gotten thrown out with the Christmas wrapping trash. Where can I find downloadable instructions? Thank you.
Hi, I can scan them to you if it's any help - just need your email address. We lost the watch for a few hours, so I know what it's like!
Dec 25, 2010 | JAKKS Pacific Toys
Toys Logo
200 people viewed this question
Top JAKKS Pacific Toys Experts
ray gallant
Scott Bright
Level 1 Expert
Tom Chichester
Are you a JAKKS Pacific Toy Expert? Answer questions, earn points and help others
