SOURCE: Bushnell Sportview rifle scope wide angle 4x38 T4389 limited adjustment inconsistant results
I had the same problem but was able to solve it by shimming the scope mounts with a thin piece of plastic. Put it under the rear to raise the sighting and under the front to lower. I still plan to buy my son a better scope.
SOURCE: dell latitude c610 touch pad left button problem
Will your laptop work properly with an external mouse? If so, check your touchpad settings in "Control Panel" by selecting "Mouse". Here you can reassign your Buttons. Try setting your Right Button function to "Double Click". If the "Double Click" function works on your Right Button then chances are you have a problem with your Touchpad Assembly which means it will have to be replaced. Dell refers to it as a "Palmrest" which they will replace if still under warranty.
SOURCE: I have a crossman 4x15 power rifle scope. Which
Under the adjuster cap there should be a scale with an arrow marked up or right (depending on which one you are looking at. If it's not marked, place the gun in a vise (gently as not to crush it, cover metal parts with a towel)
Fire the gun while in the vise at a large sheet of paper several yards away (careful where the bullet goes...use bails of newspaper or plywood backing)
Sight through the scope and move the cross-hairs 'till they are exactly on the bullet hole. After you have done that, keep increasing the distance and adjusting up to compensate for bullet drop till you reach your desired range. Side to side adjustments should only be minor. Before sighting in, make sure that the scope is securely mounted or any adjustments you make will be irrelevant. While sighting, always use a bench rest...shooting "off-hand" will never give you any degree of accuracy because everyone moves and shakes a bit.
SOURCE: How to use the BDC on my rifle scope
I got this from a website, hope it helps.
SOURCE: manual bushnell sportview 3x-9x.32 scope
The Winchester 94 ejects the spent cartridge straight up and out of the top of thr receiver. This nesesitates mounting a scope off to the side to avoid jamming the action with a spent case hitting the scope and failing to clear the action.
