SOURCE: memorex 15" HD LCD TV
THERE IS A PROBLEM ON APOWER SUPPLY MAYBE THERE IS A LOW DISSIPATING CURRENT ON POWER SEE THE USER MANUAL FOR WATTAGE REQUIREMENT OR THERE IS A PROBLEM ON BACKLIGHT CIRCUIT
SOURCE: No sound on some channels
Check in the menu to see if the audio is on SAP. If it is change it to Stereo. Hope this helps
SOURCE: STUTTER
A LOT OF THEM DO THAT WHEN U FIRST TURN THEM ON ,,,ITS CHANGING FORMATS,,IF NOT TRY ANOTHER CABLE
SOURCE: no channels found
you could try ant. on the tuner of the television and try to see if it grabs any channels on AIR ..if the scan goes all the way without finding any channels then the tuner of the television is not working. This means the mainboard will have to be exchange or repair..
This company called Amergence Technology is a 3rd party repair center and is able to offer repair services.. they could give you an idea on the repair cost and the process they have in place..
there number is 866-965-3842
SOURCE: have no sound from VCR, cable hooked up properly,
Connect RCA cables yellow, white and red from VCR to TV. White and red are sound. Select TV input where VCR cables are connected using TV remote. Try different tapes. Turn up volume on TV.
