Question about Maytag Kitchen Ranges
I have a Maytag stove. The model number is CRE8600CCE. Can I recalibrate the oven or is it a lost cause? Thanks for any help you can give.
Posted by Babette Moorleghen on
5 Related Answers
Anonymous
  • 16 Answers
SOURCE: Maytag Gemini stove with the f-1 and f1-2 problem
your lower oven temp sensor is bad. part # 12001656
Posted on May 15, 2008
Anonymous
  • 706 Answers
SOURCE: How to replace OVEN BULB
http://www.pcappliancerepair.com/model-display.php here is a link to your oven and it is shown in an exploded view. You will need to unscrew the cover from over the light bulb and then unscrew the bulb to replace with same. Hope this helps..
Posted on Sep 23, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: CRG9700 - OVEN TEMPERATURE BIG FLUCTUATIONS
biggest issue with any gas oven is a faulty ignitor, not maintaining oven temp, too long to preheat, taking too long to cook, possible slight gas smell during operation, all signs of a bad ( or going bad) ignitor
Posted on Nov 11, 2008
David Shaub
  • 2976 Answers
SOURCE: How to install Maytag oven door for model MGR5765QDQ ?
Pull the door mount bars to the first stop--where you keep the door open to broil. Slide the door back down on the bars.
Posted on Mar 08, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: maytag stove burners work but oven won't
Check the electronic ignitor. Even if it glows it can be bad eenough not to open the gas valve.
Posted on Mar 24, 2009
Maytag stove model JJW9530AAW not working
https://removeandreplace.com/2017/03/21/maytag-oven-error-codes-stove-range-fault-codes-causes-and-solutions/
Lower element stop working, wouldn't heat past 140 degrees, then tried to used the stove top and those stop working completely. Is there a safety feature to cuts the stove top off? Also is the element...
Hi and welcome to FixYa, I am Kelly
This sounds as if you have lost half of the power to your Oven. It can be from a partially tripped main Circuit Breaker for the Oven or an internal wiring problem of a burned wire or terminal. It can also be the range control itself. but I doubt that since you said the burners also do not work (depending on model) If you have separate burner controls definatly NOT the range control.
If you pass your model number we can better help you. The fact that the lower element is only reaching 140 degrees is pretty much indicating that your oven is operating on 110V vs 220V. The causes again are input power, oven wiring or the range control.
Reset the Oven CB and check BOTH ends of the range cord (if you have one) for signs of hot terminals. For a direct connection look closely at the terminal board where the house wiring connected to the oven.
With a MODEL number I can look at manuals and diagrams to better assist you. Please pass that complete MODEL number in any future responses. Most any future response I provide after I get a MODEL number will involve using a meter and opening the oven to troubleshoot.
Thanks for choosing FixYa,
Kelly
1helpful
We have a maytag performa electric stove, probabley about 6 years old, and last time we did the self clean on the oven we had a lot of stains that ran down between the inside and outside door panel. This,...
Can anyone please give me the serial number and product number to a 6 year old Maytag Performa glass top stove?? I just broke the ceramic top and need to replace it but don't have a serial number.
Thanks
Liliana.
I have a maytag performa ceramic top stove andwhen I turn on the oven it will only heat up to 230 degrees
I have a Maytag Performa Ceramic stove top which I have "washed" the serial number, I broke the glass top and need to replace it, but I don't have the model/serial number. If anyone has one please give me the numbers. Thank you
[email protected]
2helpful
3answers
I have a maytag mgr4452bdw gas stove.The top burners work fine but the oven itself will not ingnit.What could the problem be?
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Oven temp low. recalibrated up 35 degrees, 375
no you need to still recalibrate the unit if your using the baking style thermo they are famous for being off 75 degrees
Whirlpool 465 large capacity electric ceramic top oven failure
How much time I need to set to do the oven self cleaning ?
I have electric Whirpool oven 465 automatic
How to replace OVEN BULB on Maytag electric range CRE8600CCE
2helpful
7answers
F9 error
hi there,
can you tell me the model # on your stove please?
Kitchen Ranges Logo
Top Maytag Kitchen Ranges Experts
Vernon Taylor
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
