Question about Kenmore Dryers
Kenmore coin operated gas dryer not Heating. A new flame sensor, blk coils and gas line have been added. All I can see is a candle like flame and it stays on. Any Solutions?
Posted by Robert on
5 Related Answers
the dr
joey shearer
  • 447 Answers
SOURCE: kenmore gas dryer 80series model 110.c72852101
90% of all gas dryers lighting intermittently is resolved with new coil packs on the gas valve. The coils are replacable fairly easily and inexpensive.
Posted on Oct 04, 2007
Anonymous
  • 1028 Answers
SOURCE: Kenmore gas dryer not heating up
ck/replace the 2 black coils on valve they will sometimes fail after 1st start up slight chance it may be flame sensor mounted on side of burner to ck remove the 2 wires and short together temporaily if flame stays on and reignites ckd vent system first bad flame may cause sensor to shut it off if flame/vent ok replace sensor
Posted on Nov 27, 2008
Anonymous
  • 17 Answers
SOURCE: Gas dryer flame won't stay lit
Check for a blocked vent.
Posted on Mar 12, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: I have a Kenmore Series 90 gas dryer. Works fine.
The only source of a gas leak from inside the dryer itself is the gas valve. They can sometimes leak a little gas when you first turn the gas on after hooking it up. If your gas pressure is normal (and I'm guessing the plumber checked it) and your other gas appliances are working properly, the dryer gas valve is faulty and should be checked by a qualified appliance servicer.
Posted on Apr 15, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: Kenmore Elite HE3 Gas Dryer - Heat flame will not ignite
The Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Posted on Jun 20, 2009
REPLACED SoLeNOID COILS AND IT BURNS BUT SEEMS TO BE A LOW FLAME
How to fix a none heating Whirlpool or Kenmore gas dryer ...
www.askgene.com/...dryer/...dryer/how-to-fix-a-none-heating-whirlpool...
Dec 27, 2006 - How to find, test and/or replace the igniter, the radiant flame sensor ...The part number for the Whirlpool gas valve coils is 279834. ... The main coil seems to be energized all the time and the auxiliary coil is ..... I have a whirlpool gas dryer model WDG5600SQ0 ,the gas will ignite into a flame but burns out ...
Clothes Dryer Troubleshooting ' Dryer Repair Manual
Jan 01, 2016 | Dryers
Gas dryer not heating checked thermo fuse ignighter both good
Than its going to be in your heat coil/ valves and your flame sensor. The flame sensor is a rectangle box on the flame tube. Your heater coils are on the gas valve they are two round silinoids one with two pins to it and one wwith three. Follow the gas line to the gas valve on the gas valve you will see two quick connects that run to it. There is one screw and the plate cover will come off to give you access to the heater coils.
If you have anymore question please comment me back
Jul 31, 2011 | Roper RGX4634KQ Gas Dryer
Kenmore Elite He3 gas dryer (110-92832100) not heating. Igniter glows red for a min or so, drum spins, hear a loud 'buzzing' noise....
The problem could be flame radiant sensor or in most cases the gas valve solenoid coils sitting on top of the gas valves. The radiant sensor must be aligned perfectly with the igniter. The radiant sensor contacts bypasses one of the gas valve solenoid coils and as the igniter heats up it makes the sensor contact trips unbypassing the coil and allowing the gas to flow and be ignited.
The problem is with the solenoid coils,
one with 2-prongs and the other has 3, if the radiant sensor is aligned with igniter and working perfectly but no gas is ignited. The buzzing sound is coming from the coils trying to operate the valves. Replacing both coils is the simple and only viable solution.
Jul 18, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore Gas Dryer 11070852991. Have replaced the thermal fuse , operating thermostat, and High limit thermostat Still same problem . the dry starts ok egnites on and off for the 1st 10 minutes. Then stops...
bad gas coils,if you have heat for say the first 10 minutes then no heat you have bad gas coils located on top of the gas valve,when the coils cool down you'll have heat again this is what happens when they start to fail,also when you change them out on the large coil there's a metal spacer that should be on the post when you remove the coil if it isn't on the post look inside the coil you have to pop it out and slide it back on post part number 279834 remove the two phillips screws,and remove the metal cover,remove the wires from the coil and install the new coils,easy job as long as you know what to look for lol hope this helps you out and good luck
Oct 13, 2017 | Kenmore 74602 Gas Dryer
Kenmore series 500 gas dryer not heating up. model # 77542600 Other than the ignitor what could be the problem?
Check the coils on gas valve. If igniter glows bright & no CLICK sound heard after a few seconds of igniter glowing, coils are bad, or flame sensor if so equiped
Feb 13, 2011 | Kenmore 500 6952 Dryer
Kenmore Gas Dryer ignites then stops heating after ten minutes.
If the glow bar comes back on and the gas does not light,replace the gas valve coils. If the ignitor does not come back on,replace the flame sensor.
Sep 01, 2009 | Kenmore Dryers
FLAME ON SART UP NONE AFTER
Replace the gas valve coils if the ignitor glows but does not light. Replace the flame sensor if the ignitor does not glow.
Aug 29, 2009 | Kenmore 73952 Gas Dryer
Dryer will turn and start heating then goes out...it's gas
Coil valves need to be replaced.they are the 2 black rounded on top of module where gas line goes into.aout 35 bucks for both.
Mar 28, 2009 | Kenmore 74602 Gas Dryer
Nov 27, 2008 | Dryers
Dryers Logo
99 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
