Question about Whirlpool Washing Machines
My duet whirlpool washer lights keep blinking and won't stop
I stopped the machine to add something to the load and the lights stRted blinking, they won't stop and I can't restart the washer
Posted by Lynette Johnson on
5 Related Answers
Anonymous
  • 36 Answers
SOURCE: F11 code Whirlpool Duet GHW9300PWO Washer
well your close f11 is a motor control unit error or a loose connection in the wiring harness from the mcu to the motor or from the mcu up to the control panel the mcu is under the bottom kick panel un plug the washer safety first then start at the motor follow the wires back to the mcu checking wires and connectors then form the mcu up to the control board check your motor for continuity normal should be about 6 ohms between pins 1&2 then same at pins 2&3 same at pins 1&3 your motor maybe overheating and tripping out on overload then restarting when the washer motor cools down if all that checks get back with me and we will run diag on it
Posted on Dec 28, 2007
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
Posted on Nov 20, 2008
Anonymous
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
An easy Fix. Take off the kick panel, 3 screws 1/4 inch. Make sure you have a shop vac ready or a lot of towels as there will be some water. Always disconnect power to washer and dryer, and turn off water to washer. Your filter most likely is clogged with change, screws, lint, and other household stuff that we leave in our pockets! Unscrew the cap on the filter, easy to find, since you have the kick panel off! Take everything out of the filter. Take your shop vac and **** out remaining stuff in hose. Also, **** up any water that has leaked in and around the washer. Screw the cap back on hand tight, put the kick panel back on, turn your water back on, plug it in and there you go! Maybe takes an hour and saves you a repair bill. If you are not comfortable with this procedure then call a maintenance person that is qualified. 775f844.jpg
Posted on Jan 06, 2009
Anonymous
  • 6784 Answers
SOURCE: Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Posted on Oct 16, 2009
Anonymous
SOURCE: Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Posted on May 17, 2010
1helpful
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
I stopped washer while soap washing to add another item. Now it is stuck and the time is still blinking and nothing will reset it including the reset and start button. Help.
I would unplug the unit. Then plug it back in, let it spin the water out and restart the machine, do not add more soap and see it that fixes the problem.
Whirlpool Duet HT Blinking Lights at any cycle and won't work
get a repairman to look at them most likely the moters have either drawn moisture or stopped working period
Open Questions:
Washing Machines Logo
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
