Question about Kenmore Dryers
SOURCE: Electric Dryer overheating
sounds to me like you have a venting problem or the vent is plugged check the vent clean it out. make it as short as you can , also if you can use rigid metal vent...if all is clean then the blower wheel must be broken.. or loose. check for air flow out the vent ...let me know what you find..
Posted on Aug 26, 2007
SOURCE: Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Either the heater element is breaking or is loose and getting only 110V instead of 240V. First I would check the wall outlet with a voltmeter for 240V between Line1 and Line2. Also check the connections and continuity for the heater element.
Posted on Oct 11, 2007
http://www.repairclinic.com/0088_8_1.asp
Heating element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Type in model No at search tab to find parts availability
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Posted on Jul 15, 2008
SOURCE: Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Posted on Mar 06, 2009
SOURCE: Kenmore Elite HE5 Electric Dryer
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
Posted on Aug 29, 2009
Dec 12, 2015 | Kenmore HE5 Electric Dryer
Jun 16, 2012 | Kenmore HE5
Mar 27, 2011 | Kenmore Elite HE3 Steam 8674 Dryer
Mar 20, 2010 | Kenmore Elite 45986 Front Load Washer
Nov 24, 2009 | Refrigerators
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
Jan 14, 2009 | Kenmore Elite HE4 Electric Dryer
Aug 20, 2008 | Kenmore Elite HE4 Electric Dryer
May 07, 2008 | Kenmore Elite HE4 Electric Dryer
Jan 20, 2021 | Kenmore Dryers
324 people viewed this question
