Question about Ricoh Office Equipment & Supplies
What can i do in order for me to use mp4000sp ricoh printer controller on mp5000sp ricoh printer?
Posted by Alick Kaunda on
OfficeServiceAjnc
  • Ricoh Expert
  • 215 Answers
Sorry not possible to be done. All other parts and boards are same on the both models. Even the RAM and the printer\scanner SD card is the same.NV ram is the same. But the controller boards are different for both machines. You will get SC995 if you put a mp4000sp controller board in mp5000sp.
Posted on Jun 26, 2018
2answers
How can I fix SC 990 error in Ricoh mpc2051
the approximate meaning is that the software in your printer has attempted to perform an unexpected operation. So, if you're attempting to use a certain function on your printer, please restart and try once more. Otherwise, you might need to consult the printer manual to help troubleshoot the code.
Thank you.
1helpful
How do I Fix Error Code SC899 on Ricoh Printer?
https://www.google.com gives suggested fixes, depending upon which model of Ricoh printer. Do you know what model of Ricoh printer has this error? Use the Comment menu to add information to your questions in order to receive suggested fixes from FIXYA unpaid volunteers.
https://www.google.com/search?q=SC899+on+Ricoh+Printer&oq=SC899+on+Ricoh+Printer&aqs=chrome..69i57j0.4207j1j8&sourceid=chrome&ie=UTF-8
HOW DO I CLEAR ERROR CODE SC995 on Ricoh mp5000
Sorry not possible to be done. All other parts and boards are same on the both models. Even the RAM and the printer\scanner SD card is the same.NV ram is the same. But the controller boards are different for both machines. You will get SC995 if you put a mp4000sp controller board in mp5000sp. SC 995 is compatibility error for the controller board it self.
3answers
It says communication error on ricoh 3050sfn printer
Please :
- Check your ricoh driver on your PC ( you must have the driver installed at your PC)
- Check PC - printer cable connection ( It must connnected securely)
- Set your ricoh printer as default printer on PC ( Go to control panel, click printer, right click ricoh and choose default printer).
Regards, Jay
Hello we have one printer Ricoh 2015 we want to connect to network printing . It is possible
In order to connect it to a network, you need to have the print/scan option installed. If your copier has the print/scan option, you can hook it up with an Ethernet cable and download the print driver from the Ricoh website:
http://ricoh-usa.com/downloads/software.asp?tsn=Ricoh-USA
RICOH AFICIO 1045. ANY BUTTON AT RIGHT OF THE ...
turn off and unplug remove two screws on top near the glass jn order to remove the control panel slide panel toward your tummy bottm side has wiring harnesses check these connectorsare tight also look fer cracked solder joints on right side for numeric keypad if you know how to soldera pcb new control panel is about 800.00
Ricoh aficio firmare
You must have a Ricoh tech ID in order to download machine firmware. You can get the firmware from Ricoh's tech website, TSCWeb.net if you have a valid Ricoh ID.
Hi.when i m switch on the Ricoh 3310L Fax,the message is coming as shown below "time to change PCU"
Order a new PCU from Ricoh. Power off the machine and replace the pcu.
If you try and cheat it it will run for a short while and then lock-up breaking some gears. Cheeper just to order a pcu. Check Ebay, i see alot of Ricoh supplies there.
Ricoh 1027 what is the scan option part number?
The Printer/Scanner Controller Type 1027 part number is 411000 (product code B453), but I'm pretty sure that it's obsolete. Contact Ricoh customer service to find out if you can still order it.
1helpful
PCU running out quickly
the best bet would be to order from Katun US if they have the specific toners for your Ricoh printers, as an ex ricoh tech supervisor i recommend using brand toner just because it is manufactured to exacting specifications and will not void any warranties, or as Stated try this link to the Katun catalog http://www.katun.com/downloads/PrinterConsumables052009-NA.pdf
if this answers your query please rate my expertise accordingly
Regards
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
