Question about Ricoh Office Equipment & Supplies
HOW DO I CLEAR ERROR CODE SC995 on Ricoh mp5000
Posted by Alick Kaunda on
OfficeServiceAjnc
  • Ricoh Expert
  • 215 Answers
Sorry not possible to be done. All other parts and boards are same on the both models. Even the RAM and the printer\scanner SD card is the same.NV ram is the same. But the controller boards are different for both machines. You will get SC995 if you put a mp4000sp controller board in mp5000sp. SC 995 is compatibility error for the controller board it self.
Posted on Jun 26, 2018
5 Related Answers
Anonymous
  • 287 Answers
SOURCE: Ricoh Aficio 1224c
Hello billboards,
SC 570 means that despite the fact that the the copier had been giving a "FUSER OIL LOW" prompt in the upper left hand corner of the display for quite some time, the prompt was ignored and now the oil is more than low it is empty. You will first need to aquire fusing oil for your machine.Typically it would be purchased from the same source you would aquire toner as it is something that is consumed as the copier is used similliar to toner. Once you have the oil you will need to replenish the copier's supply of oil. To do this you will need to access the back of the machine. Once you are at the back of the machine,look down to the lower right hand corner. You will see a small square panel with what I would describe as an oversized white plastic flathead screw that needs to be turned counterclockwise to release the small panel/cover. Once you remove the cover you will see a clear container witha black screw on cap. Unscrew it,and fill the container with the oil and stop filling when it reaches the neck of the container. Button everything back up and now you are halfway out of the woods. Now we go to the front of the machine. We need to reset the code. There is a yellow rectangular button above the nine key pad used to enter the number of copies you want. Now that you have located it, press it once and then press the "1" then the "0" then the "7" and then press the round red stop button and hold it down until the screen changes and beeps. At this point the display will have several blocks showing. One of the blocks will say "copier".Press the copier block. Now you will have a drop down menu to the left and several options across the top of the display. At the top,from left to right,the fourth box should say "SP DIRECT" and should actually already be highlighted. At this point,merely press "5810" on the keypad and then press the " # " pound sign. The pound sign means enter. At this point you should see a prompt that says something like "SC reset" and there will be a bar below the prompt that says "EXECUTE" .Press the execute button. This resets the code. But now you must turn the main power off (the red switch located next to your left knee on the front panel of the copier) and wait a few seconds. Now turn that switch back on and you should be good to go. I just reviewed my instructions and wanted to stress that the yellow button above the nine key pad says clear/stop. Just wanted to be more specific. I bet you have this problem whipped in no time! I hope this helps.Take care and good luck.And please feel free to let the folks at "FIX YA" know if I helped you. I don't get paid by them but I like the pats on the head . :-) ...........spinal.......
Posted on Apr 19, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Posted on Jun 19, 2008
Anonymous
SOURCE: have error code 990 on ricoh gx 3000 printer how do i clear this?
you can try pulling out and reseating the Waste Ink tank which is located behind the machine behind a plastic door cover (left side of machine as you are looking at it from behind). Turn the machine off and on using the main power switch. If the code comes back then you will more than likely need a new Waste Ink Tank.
Posted on Apr 24, 2009
Ickoajnc
OfficeServiceAjnc
  • 215 Answers
SOURCE: Ricoh 1232c copier error code sc 517
The error is about the fusing unit for to reset the code you must enter into the service menu and reset the SC code 517
For to enter the service menu you should do the follow steps :
1.Enter the service menu by pressing the follow keys in order: yellow key[clear modes] then press "107" number one after other and then press and hold the red key [clear/stop]
2.Hold it down until service mode do not appear if not appear after 10 seconds try again.
After you will be in service mode press the follow numbers :5810 and then will apear on the screen "SC reset" set the value from "0" to "1".
Then turn off and after 5 seconds turn it on the machine.
Please replay if this do not help and write the SC code good because i cannot find the code SC517
Posted on Jul 15, 2009
Anonymous
  • 114 Answers
SOURCE: I'm replacing drum, developer, drum cleaning blede
After replacing the drum, do these SPs: ?? SP 3001-2: ID sensor initial setting ?? SP 2810-1: Grayscale Setting
Posted on Apr 18, 2010
How can I solve SC 995 error for Ricoh Afcio 2027?
SC995 is a controller board not compatible error. You have replaced the controller board with the 2022 or 2032 board. All other boards and parts for this machines are the same. Only the controller board is different for all three models. But if you have not change the controller board and this SC995 appeared then the controller board is defective and need to be replaced.
After it starts, why does error code sc995-03 appear?
?? Incorrect type controller installed
?? Defective controller
1. Replace the controller with the correct type.
How do i clear error code sc995-03
This a model information error.
The engine firmware not installed correctly.
Reinstall firmware.
How to clear error code Sc995-03
-Incorrect type controller installed
-Defective controller
3helpful
Ricoh mp5000 error code sc220?
1) The Copy Data Security Unit card not installed
2) The Copy Data Security Unit card is installed, but it is not the correct type for the machine.
Sc819 trouble/error in ricoh aficio mp5000. any help? thank u
SC819: software error. upgrade controller to the latest version. Faulty RAM and ROM DIMMs also cause this problem.
Ricoh Errors
Ricoh jp 5000 errore code message ec 5-51
Its a MP5000 right??
You have Loose connection of pressure roller thermistor.
Try this:
Press the clear mode key (yellow key)
Use the keypad to enter "107"
Old down clear/stop for at least 3 secounds (red key)
Enter the service mode (on the touch screen press "copy mode")
Exit all the way to return to the copy window.
Turn the machine off/on.
If doesn´t work you have to call technical assistence.
1helpful
2answers
Error sc551 en Aficio PM 1500
Enter in the service menu,activate the SP mode,open the front door,close the main switch,unplugged the machine.Wait 10 sec. close the front door, plugged the machine and turn ON.
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
