Checked uses grounds when blower stops no power
The blower motor control processor is going out . The blower motor is controlled electronically .
The fuse for this is located in the rear fuse box , under the box seat . HVAC BLO fuse 40amp
HVAC Blower Motor Circuit
GMC Yukon HVAC Blower Motor Won Turn On
SOURCE: Clutch not disengaging when stopped at a stop sign for a period o
It is either your clutch master bleeding down, or your slave cylinder is leaking. Should be able to check inside the truck for a leak from behind the clutch master, the slave is by the trans.
SOURCE: No power to blower motor on grey wire
I would say the blower motor resistor has gone out. The front dash module or the rear one.
SOURCE: I hope you can help me out but my blower for some
Does it have manual control or automatic climate control?
SOURCE: blower moter resistor works sometimes
You have a bad connection. more than likely a bad ground on the blower. Your A/C shuts down because of low suction pressure. The fan needs to be running and blowing through the evaporator.
SOURCE: Heater blower motor starts up
The brushes inside your blower motor are bad. You need to replace your blower motor.
