Precor Error 44, Un-commanded Lift Motion
Probable Cause
1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Typically on the Precor Treadmills if there are errors on the unit, you can press and hold the stop button for 3-5 seconds and it will go into the error log. Not sure what model you have. E-2 is not what normally shows up on the screen. Do you mean Error 2 was displayed? From what I have read on Error 2's it could be a upper PCA issue, or possibly a dip in AC input during the power up sequence. Treadmills require a dedicated line, meaning it is on its own dedicated circuit on your fuse panel/circuit breaker. What exactly is the treadmill doing? Is it constantly showing Error 2 on the screen? Call up Precor tech support. They will be able to give you advice, and or get you connected with an authorized Precor factory trained technician who will be able to get you back up and running.
With
a few more details I am sure we will be able to work through is issue together
and get you back into your exercise program shortly. If you would please
give us a call at 1-800-347-4404, one of our technicians will be more than
happy to assist you. Please give us a call at 1-800-347-4404
Mon-Fri 6AM-5PM, except Thur 6AM to 3PM, Pacific time. - Precor Customer Support Team
UVW-1800 error 02-694 indicates a problem with one or both reel motors. check the cables going to both motors; have seen failures related to these cables.
