Question about Polaroid Office Equipment & Supplies
My Polaroid pogo won't do a thing. I send pic from phone it goes to pogo the green is flashing then flashes fast but it's not printing ,the blue paper not working or clean itself, it's just dead Help
Posted by Julie on
5 Related Answers
Anonymous
  • 43 Answers
SOURCE: Sony KDF-E55A20 55 in. LCD... Problem red light flashes 5 times
A 5 blink error indicates a bad lamp driver. However a lamp may possibly cause this too. I suggest putting a new lamp in if you have one just to verify the lamp is not the problem. If it still fails with a new lamp then the lamp driver is the problem. This part should be replaced by a Sony authorized servicer. The lamp can be replaced easily by you. The lamp replacement instructions are in the TV's owners manual. Good Luck
Posted on Jan 06, 2008
Anonymous
SOURCE: lights flashing, printer won't print as a result of a paper jam
Hi Girlemom. Just had the same problem here. Lift up the lid and slide the ink cartridges to the left. If they are stuck in the middle, this will prevent the printer from starting properly. Then, unplug it, plug back in, and turn on. It should restart normally.
Posted on May 21, 2009
Anonymous
  • 4 Answers
SOURCE: how do i get my flashed cricket moto q to send and recieve pics?
The first bar withh all the numbers in it is actually [email protected]
...so put your number where all the numbers are.
the password is cricket.
i had the same issue:)
leave the domain empty.
Posted on Jul 02, 2009
Anonymous
  • 14 Answers
SOURCE: my polaroid pogo wont print
when printing make sure that the paper is inserted in the pogo shiny side up and logo facing down. also try putting through the blue alignment sheet first as the pogo will not work without this. hope this helps
Posted on Oct 30, 2009
Anonymous
SOURCE: Polaroid PoGo Digital Photo photographs streaky with purple edge
TO CLEAN PRINT HEAD, TAKE AN A4 SHEET OF PAPER CUT IT TO SIZE FOR THE POGO,BUT MAKE IT (3) THREE THIKNESSES THIK, FEED IT IN UNDER THE PRINT HEAD AND CLOSE LID, WHILE THE PAPER IS BEING EJECTED PUSH UP ON THE PAPER THAT IS BEING EJECTED WITH YOUR FINGERS, YOU MAY NEED TO DO THIS A NUMBER OF TIMES, BUT IT WILL CLEAR THE STREAKING. IT WORKED FOR ME AND MY POGO DOSE BRILLIANT PRINTS.HOPE THIS HELPS PEOPLE. JB
Posted on Feb 25, 2010
I have a samsung GT-S5570 which has paired with my pogo however the red light flashes on the pogo and my phone says jpg not sent each time, please help!!
I found out that mine cannot print if there is a "dot" or specifically, "." in the file name. It will start flashing red light as if there is a paper jam. I renamed the file and the problem is resolved. Hope this is helpful.
2helpful
2answers
Streaks in pictures tried to do what it says in the instructions did not help
Try sending the blue registration paper with the barcode through the printer.
10helpful
3answers
Samsung galaxy s cannot get pogo printer to print!!It say it is paired but not connected
Download the "Polaroid Pogo App" from the Android Marketplace. This will solve the problem of the Pogo rejecting your phone. It also has other features like different "frame shots" or printing one picture over 4 sheets. Best of all - it's free!
3helpful
My polaroid pogo wont print
3helpful
Bought today..does battery have to be charged for 3 hours before use? please advise
first of all make sure that the pogo it turned off insert the paper from the packet with the blue peice on the bottom with the barcode facing down. and the paper facing shiny side up and logo face down. when you turn the pogo on the blue paper will feed through first then the printer is all setup and aligned ready to print via bluetooth or via USB cable. hope this helps
6helpful
2answers
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
Top Polaroid Office Equipment & Supplies Experts
Steve Nordquist
Steve Nordquist
W.L.
Clive
Clive
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
