SOURCE: shredder
Check for stuck paper and remove if any. Then check if motor is ok with a multimeter and also main switch.
SOURCE: Shredder suddenly runs only in reverse
Do you hear the motor moving in both directions? I just had the same problem with mine. On mine, you can hear the motor moving in both directions but it would only move the shredder teeth in reverse and the teeth would not move going forward. I took the unit apart and found out that the gear right next to the motor shaft was rounded out in the middle. The solution would be to get a new gear or gears if you can get them. Make sure you inspect all the gears to see if there is a lot of play. You might have to replace more than 1 gear. What I did on mine, was take a brass tubing that was just a little larger than the shaft, drill out the center of the bad gear and press the tubing into the center of the bad gear. This took up the extra play and my Tech Solution TS8000 is working again. Hope this helps. If you have any other questions, feel free to email me at [email protected]
SOURCE: My shredder stop shredding. has paper caught in it
Shredder drive gear is probably shredded - hard part to find or replace usually. Could mean a new shredder;-(
SOURCE: shredder problems
Seems it could be a problem with one of your sensors Fellowes Customer Service can easily and quickly diagnose your problem. 1-800-945-4545
SOURCE: Shredder Malfunction
Sounds like you have a jammed shredder. Unplug it, and then look under the shredding output side. You might see a bunch of compacted paper in there. If so, you'll need to have someone take it apart and remove the paper. Be sure the shredder is UNPLUGGED before you or anyone else attempts to do this.
