Question about Lanier Office Equipment & Supplies
Lanier lw310 wide format printer/copier has a cable with a 26 pin MDR connector. How can I connect this to my ASUS computer?
5 Related Answers
Anonymous
  • 115 Answers
SOURCE: printer busy/or error
Sounds like your machine is using DHCP, not a static IP address?
Print your network settings from the Printer, then try to Ping from a computer on the network.
Check the Network setting of the machine, make sure it is set to a fixed (static) IP Address.
If this is the problem, you can go into your PC printers port and change the port to the reassigned IP Address of the machine.
If you reinstall the drivers then you will have this installed twice, one will work one will not, so delete it from the printers folder before you reinstall before you reinstall
Posted on Oct 25, 2008
Anonymous
SOURCE: need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Posted on Jan 07, 2009
Anonymous
SOURCE: Lanier copier won't scan to computer
IF you're scanning to folder, check your security settings in file sharing. Try allowing all permissions to each listed and apply.
If you there is a computer that you know definately works already, have a look at their settings in security tab of file sharing - and change permissions to allow full control (for now). See if your scanning works.
Posted on Feb 05, 2009
Anonymous
  • 72 Answers
SOURCE: Looking for identification of wiring pin-outs for
Take your time; when it comes to that you must take your time Look for matching connectors
Posted on Mar 23, 2009
Anonymous
  • 134 Answers
SOURCE: ASUS P5KPL-AM CPU fan connection.
You should still be able to connect the 3 pin connector of the fan to the 4 pin connector on the mobo, the keying tab is offset so that you cannot connect it to the wrong pins.
If you still don't want, or can't connect it there, simply go on the Bios (press delete after you turn on your computer) and you will find an option to monitor CPU fan speed.
If you need any more help, let me know
Alex
www.CAS411.com
Posted on Mar 28, 2009
My computer gives continuous long beep on boot. No display on monitor.
Sometimes this means that some connection hasn't been made between the motherboard and the power supply. Often, after connecting the power supply's 24 or 26 pin connector to the motherboard, people forget to plug in the little 4 pin connector. That's usually located near the processor. I hope this helps!
Apr 10, 2011 | ASUS M2N68-AM SE2 Motherboard
How can i open it and where to find the charger ?
  1. Connect the power cable to the jack on the sync cable adapter
  2. Connect the 26-pin device plug of the sync cable to the 26-pin connector to the bottom of the device.
  3. Connect the power plug to the grounded wall socket.
The LED indecator will start to flash green as soon as it begins to charge.
Jan 15, 2011 | ASUS Mypal A730W Windows Mobile 2003
Looking for some one to work on a gestetner a045 in louisville ky
Your Gestetner A045 is made by Ricoh. I will be a lot easier finding a Ricoh dealer than a Gestetner one. Here are the equivalent models for your machine. That is, any dealer listing that they service Ricoh, Savin, Lanier or Gestetner should be able to service it.
Your machine is the same as:
Ricoh Aficio 240W
Savin 2400WD
Lanier LW310
Good Luck and Thank You for using Fixya.
WheatlandServices
Jan 06, 2011 | Gestetner A045 Wide Format Copier
I need a cable to enable connection from Epson lq 1050 to my computer - (DELL Inspiron-530S)
The "data" cable for a printer either is:
* USB -- a small almost-square socket, less than 1/2 inch (1 centimeter),
* parallel-port -- a very-wide connector, more than 2 inches (5 centimeters).
Some printers have *BOTH* connectors.
Determine which connector(s) you have, and buy a cable.
Often, a "Thrift Store" will have the "parallel-port" cable for a dollar.
Don't pay more than $4 for a "USB" cable.
If you're buying a USB cable, make sure that there is a "square" end -- some USB cables have a smaller "mini-USB" connector, in order to connect to a digital camera.
Nov 27, 2009 | Epson LQ-1050 Matrix Printer
How do I add a second HD
Turn the machine off
Open the case
Look to see if there are IDE connector (Wide Flat cable with a connector usually grey)
If this is not present look for a SATA connector usually a small red or blue wire similar to a cat5e network cable
Scew your HDD in place in the rack connect the cable either IDE or SATA
If you have an IDE drive look for a 4 pin female connector from the power supply
If you have a SATA drive look for the connector from the power supply
Once all is connected then reboot you computer typically your bios should auto detect it.
Let me know what happens from here
Sep 19, 2009 | Dell Precision T3400 375W 32bit Computer...
I have a Lanier 5245. I am getting an error when
Your duplex is the big box on the right side of the machine push the back side shut against the machine and try again
May 08, 2009 | Lanier 5235 Printer
Hook Up possible for EPSON Stylus 880 to new computer w/USB ?
There is no conversion cable that you can use with parallel connector since USB transfers data in Serial mode and the parallel cable handles data in Parallel mode.
Sorry.
Mar 01, 2009 | Epson Stylus Color 760 InkJet Printer
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
117 people viewed this question
Top Lanier Office Equipment & Supplies Experts
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
