Question about Vision Televison & Video
Why My Star vision TV is powered on but cannot turn on
Posted by david homboura on
Star vision TV has sound but no picture. Just white screen
David that is a hard one to diagnose without some higher end test gear...it literally could be any of the boards in the TV causing this and replacing them without running some tests is a waist of money.
May 05, 2018 | Televison & Video
Vision quest renoir
First check the power supply of your TV,multimeter the export voltage of power supply.if it is defective you can replace it.
if not you need check main boards,and inverter boards
From Wisiny.com can find those parts,power supply,inverter boards and t-con
Dec 09, 2013 | Televison & Video
Servicing sheet tv gold star model cf 20a90y
You could try checking the glass buzz fuse inside of the television located on the circuit board......
If not, try using google to do a search for your model's repair guide...
I hope this helps...
May 14, 2013 | Televison & Video
Where is the power button of this aquos cardio vision tv? Is there any other way to turn on tv?The power button on remote can't work today.
First thing if there's a TV Button they pushing cause someone might of pushed the SAT or. DVD button. If that don't work check your battery's. some times I tap mine for hand hand lightly and then it works Good luck
Mar 19, 2013 | Televison & Video
Cannot see thru optics. ifr comes on but still cannot see any image? can the back of the night vision come off to check the power illum light?
Hello, so the image intensifier tube light up. Shake it and listen for parts raddle around inside.
How long have you own this Night Owl? Have you been using night vision on bright lights?
If you have the intensifier tube is gone back to the Red Star....it died! The IR operates on a different switch than the controler, ccfl inverter, multiplier, image tube. Sorry. stewbison
There is good bet that I have a tube for this, but it not worth sending to me. Also, maybe it not the image intensifier tube but something else in the electronic.............Made in Russia--Red Star
Aug 02, 2011 | Night Owl Optics Cyclops Compact NOCC3...
How do you connect a fujitsu p42vca30eh to a BT Vision box? Which cables are needed? Thanks Emma
You should use a HDMI cable. This cable will carry the audio and video from your Vision box to your plasma screen. Connect the cable to the HDMI port on the vision box and the other end to HDMI 1 on your TV. Once that is done turn on the vision box and then the TV and switch the TV to HDMI 1 using your tv remote and then once you have a picture use your vision box remote to change channels and perform other functions. techpunk_0.jpgtechpunk.jpg
Mar 02, 2011 | Fujitsu Plasmavision P42VCA30EH 42 in....
No sound or vision set tripping power supply ?
no, you need the main board
if the tv turn on you need the main board if your
tv do not turn on you need the power suply
Aug 13, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
My vision quest tv turns on but its just a black screen
turn the rocker-type power switch off at the bottom right side. While holding down the power on/off button, turn the rocker-type power switch back on while continuing to hold the power button down. After about 15-20 seconds you should see the input selection menu. From there your tv should continue to operate normally.
Jul 15, 2009 | Televison & Video
RCA universal 3 digit remote code for diamond vision TV
turn on your tv.Then push the code search button until the led still ,when the led keeps on let go the button now push and release the tv button then push and release the power button until the tv goes off,when the tv turn off stop to push the off button now push the set button the code are already set on the remote control( you might got to push the off button almost 100 times or more until you get the right code for your tv.Good luck
Aug 09, 2008 | Televison & Video
Televison & Video Logo
Top Vision Televison & Video Experts
Marvin
Marvin
ray gallant
Are you a Vision Televison and Video Expert? Answer questions, earn points and help others
