SOURCE: How do we connect a forest river pod to home
The R-Pod use 30amp power (110vac). You can buy an adapter that will reduce the plug from 30amp down to 20amp which is typically what your home outlets will be. Keep in mind; however, that when plugged into 20amp or 15amp service you will not be able to safely run the AC with any other appliances, or the refrigerator on electric with other appliances, etc. The concept for the adapter is so that you can plug in at your home to a standard outlet to turn on the lights while you pack the camper and load the refrigerator. It is not designed for long term use.
SOURCE: I have a 2000 forest river 31 bhss. I was looking to find out what the correct weight of it .
Travel Trailer Archives - DNL Recreation ' #1 Camper ...
dnlrec.com/body_style/travel-trailer
Sort By: Price Dry Weight. Results Found: 39. 39. 2016 RPod 171. Condition New DryWeight (lbs) 2,205 .... 2016 Puma 31BHSS ... 2016 Forest River 31BHSS
or try wikipedia
SOURCE: 2015 Forest River Solera RV. Where is the tail light fuse for this RV? Thanks!
it will be found in the vehicle fuse box under the dash
probably marked tail lights / park lights
Testimonial: "Those fuses are not marked."
SOURCE: Is there linoleum under the blue carpet of the 2005 forest river fifth wheel grand surveyor?
You'll probably just have to lift up an inconspicuous corner of the carpet and look. Most of the time it is just pressed wood.
