SOURCE: codes for daewoo tv, ge remote model 24912
Codes for Daewoo are: 0451, or 0092
If this doesn't work with your new remote there is always the way that I have done it in the past and that is to use the find the code function on your new remote. It is a pain but can be done and is quite effective. Each remote is slightly different, but for the most part you would hit the set up botton and hold it in until it starts flashing then hit the T.V. Button and then hit the first code it tells you to hit and then hit the power switch if it doesn't turn off your T.V. then you hit the increment button up, (this is different for each remote so it is important to follow the instruction manual on this part) You bassically keep hitting the incriment button until your code comes up and then it will turn off your t.v.! Then your done. Note: It may take up to 400 pushes of the increment button, but it will work.
SOURCE: LG LCD flat screen TV - 42LG50-remote control is unresponsive
Sounds like a probable main board issue
SOURCE: 61md10 front panel controls lit uo, but the TV does not respond
With a non responsive remote that would be inpossiable you need to replace the control board inside around $100 bucks then you can have a good tv again but to get to the service menu your controll has to be working.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Testimonial: "I'll try the fix. Thanks for the info!"
SOURCE: codes for Daewoo TV & DVD on Ge UN Remote #
go on their website there is always a list of codes
SOURCE: TV doesn't respond to the remote control.
surface mount capacitors on ir receiver board are shorting
Testimonial: "Thanks I'll be checking them."
