Samsung dishwasher DMS500TR not explained showed F2 what does zf2 mean. Manoel shows F1 to F9 but not F2
Hi, F2 means that the Main Control Board is not getting the right signal from the user interface, turn off the power to the machine & then go to you tube there are several videos showing the correct way to remove the screws to give you access to the inner door liner to check all the contacts are clean & connected properly, as if this doesn't correct it then the user interface is probably the cause as it is most likely faulty & needs to be replaced, but to be sure I would follow the step by step tutorial on you tube for your make & model....
I hope this helps....
SOURCE: what does F1 mean?
F1 means you either need a new touch pad or a new control board. Usually it's the touch pad. Hope this helps, APP tech http://www.AppliancePartsPros.com
SOURCE: D3350 - Code F9
Service manual says:
LED L1+L2/Fault code F7, Pumping out fault
(machines with pressure sensor)
Water not evacuated after 120 seconds’ pumping
out. Programme interrupted.
Check: Drain pump, hoses, installation of drain
hose, control unit and wiring.
SOURCE: maytag electric range shows F1 error message and beeps
f1 is a bad range
control/ touchpad, here the part number for a white clock for model number
MER5770aww 74008106 approx 150 bucks
SOURCE: Fisher & Paykel dishwasher:
Turn off dishwasher's circt braker at distribution panel (usaly located in garage or in basement)
1. Open lower drawer
2. Push in two plastic buttons at front lower corners.
3. Remove drawer from railing
4. Remove water from bottom of dishwasher
5. Use hair drier to dry off bottom copartment, specialy in left corner at floding switch location.
6. Install drawer on the rail in position when plastic buttons pup up
