Question about HP LaserJet Office Equipment & Supplies
SOURCE: FUSER ERROR AND PAPER JAM
Not a guarantee, but i had similar issue with a past HP Color laser and it was heat related...moved it away from window out of the sun and problem went away.
Posted on Sep 24, 2008
SOURCE: paper jam HP Laserjet 3050z
Open tray 1 and pull any visible jammed media out of the all-in-one.
If no media is visible, open the print-cartridge door, remove the print cartridge, and rotate the
upper media guide. Carefully pull the media up and out of the all-in-one.
Close tray 1.
Posted on May 04, 2009
SOURCE: HP 3015 Laserjet paper jam error message
The paper is probably jammed between the fuser and the rear cover if you can't see it.
Posted on Aug 18, 2009
SOURCE: HP LaserJet 2430n is not grabbing the paper like it used to
You need to replace either the pickup roller or the separation pad (or, optimally, both at the same time) - both should be removable without tools, they just snap in. You can order new parts at http://partsurfer.hp.com - shouldn't be more than $20 worth of parts. You can help reduce the problem slightly by roughing up the rubber on the pickup roller and the cork on the separation pad by scuffing both with a light grade of sandpaper, just to give it some tooth. But replacing them is best, it'll fix it!
Posted on Oct 20, 2009
SOURCE: My HP PS C4180 all-in-one paper jam error
Hello there
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 27, 2010
Aug 02, 2017 | HP Office Equipment & Supplies
Mar 12, 2014 | HP LaserJet P3005 Printer
Mar 23, 2013 | HP LaserJet 4350 Printer
Aug 11, 2011 | HP LaserJet P4015 Printer
May 31, 2011 | HP LaserJet P4015 Printer
Mar 24, 2011 | HP LaserJet P3005 Printer
Jan 11, 2011 | HP LaserJet 3000n Printer
13.20 PAPER JAM CHECK REAR DOOR
Media stopped in the paper path during power on
or when the top door was closed.
Action:
1.
Open top cover and remove toner cartridge. Remove all media in the
paper path, and then re-install toner then open and close the top cover.
2.
Open read door and pinch blue latches on fuser and pull it out.
Inspect the sensor flag for correct movement and any paper obstructions in the
fuser rollers. Re-install fuser and Confirm rear door closure.
3.
Remove tray 2 and confirm paper is not jammed in the pickup area.
Confirm paper size adjusters in the tray are correctly set for paper being
used. (Do not set back paper stop to ANY)
4.
Replace any defective sensors or flags
Hope this helps. Please keep us updated and
remember to rate this answer.
TF
May 24, 2010 | HP LaserJet P4015N Printer
May 06, 2010 | HP LaserJet 2420 Printer
Apr 02, 2008 | HP LaserJet 4 plus Printer
Dec 30, 2020 | HP LaserJet 1320 Printer
388 people viewed this question
