Question about Taylor Health & Beauty
Error message "___" on digital scale 7404. Tried to reset after I changed batteries, and got the same error code. What can I do to fix it so I can use it? Is is done for?
Taylor digital scale 7404 stainless steel finish.
Posted by Sarah R on
  • Taylor Master
  • 18,562 Answers
--- usually means that the unit cannot calibrate itself on start up. The sensor is out of range. THis could be from being dropped, or something too heavy was put on it. They cannot be reset.
Posted on Feb 22, 2018
5 Related Answers
Anonymous
  • 74 Answers
SOURCE: ERROR message
This link allows you to troubleshoot directly with the company...I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
Anonymous
  • 74 Answers
SOURCE: taylor digital bathroom scale
This link allows you to trouble shoot directly with the company... I hope this helps. http://www.taylorusa.com/advantage/root/contact.html
Anonymous
SOURCE: Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Posted on Oct 18, 2009
rockmeister
Rockme
  • 2047 Answers
SOURCE: Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Posted on Sep 02, 2010
christyrse
Christy Fredericks
  • 45 Answers
SOURCE: the Taylor bathroom scale is
If the scale is moved or bumped, or the battery is replaced, the scale needs to be initialized before use.
To initialize, just press on the platform with your foot. The display will turn on and off. The scale is ready for use once again.
Posted on Sep 26, 2010
I have changed to batteries twice but I Continue to get error messages. What to do now?
If the batteries are good the hassle has to be with the electronics.
If the pressure sensor is in the on position when booting, that could result in the error message you are getting - make sure it is open when booting up the unit.
Nov 05, 2015 | Homedics SC-405 Digital Bath Scale
The taylor lithium electronic scale says 00 and then ERR. there is no ERR2. should i change the batteries? it never said lo.
If you get an "Err" or "Error" message, you will need to step off of the scale, wait a few seconds and then step back onto the scale.
Aug 10, 2010 | Taylor & Digital Scale Lithium Scale
Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
From the Taylor Site http://www.taylorusa.com/faq-scales
Here are the basic ERR messages and their meanings:
  • Error 0: Initialization
  • Error 1: Instability (scale is on an uneven surface ex: carpet)
  • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
  • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
  • Error 4: Body fat is out of range
  • Error 5: Water is out of range
I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 15, 2010 | Health & Beauty
Canon PowerShot A420 reset lens error message
Not a solution, but a smilar problem with Canon Power shot A2000IS. Same lens error. reset camera message. Lens alos in fully open position.
Also in Costa Rica.
Any suggestions?
Neil
Jun 24, 2009 | Canon IXUS V2 Digital Camera
Error message ErrL
My scale had the same problem.  I replaced the battery, but still got the same message.  My wife noticed that one of the feet on the bottom of the scale was loose.  The feet are twisted on to the scale and held by two small flanges.  When I gently pulled the loose foot away I noticed that a small black wire had broke.  I used my fingernails to remove a small bit of the wiring cover and twisted the ends back together.  I then hide the wires back in a recessed area on the foot and placed it back on the scale.  Worked just like the day I got it.   Hope this helps!
Jan 28, 2009 | Conair Weight Watchers Glass Digital Body...
ERROR message
Jan 02, 2009 | Taylor 7506 Precision Tech Lithium Battery...
Taylor Scale 7532s - not working
This link allows you to trouble shoot directly with the company....I hope this helps.
Dec 19, 2008 | Taylor 7532 Ultra Thin Glass Digital Scale
Health & Beauty Logo
111 people viewed this question
Top Taylor Health & Beauty Experts
Marvin
Marvin
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
